Originally Posted by mkaye
my mechanic is leery of the urethane bushings - squeaking
whiteline supplies grease to alleviate that
I have already sunk $3500 into this & some other problems since the rough road trip in Oct for my 1999
I am definitely looking for the cheapest solution to get rid of the wobble
not sure that replacing the panhard & trailing arm bushings will solve the problem, other bushings may be worn i.e. upper control arm
thoughts?
mark
Toyota replacement prices from mechanic:
lower arm bushings $77x4 (or replacement @$359 ea)
panhard $504
upper arm $282x2
I can get the panhard & lower control arm bushings for CDN$188
I used poly bushings in all my rear axle stuff: upper and lower arms and panhard. No squeaks after 2+ years, all is well.
