02-13-2009, 05:34 PM
license plate lights??? help me
i need to replace both licens plate bulbs. i took the two screws out of both lights and got one fixture to come down, but i couldnt figure out how to get it a part and the other one wouldnt even come down out from under the trim on the lift gate i need help figuring these retartedly designed things out!!!
check out my build thread My Build
02-13-2009, 06:11 PM
Moderator
Real Name: James
Moderator
Real Name: James
Re: license plate lights??? help me
the clear part literally just comes off.
and inside is a clear 194 bulb.
That's it!
IG: @jimharb | YouTube | '99 Limited 2WD |
'99 4Runner - 2.7L 3RZ-FE - TRD S/C - 4WD Conversion + R150F 5-Speed Swap - Imperial Jade Mica on Oak
'87 4Runner Turbo - 2.4L 22R-TE - CT-26 Supra Turbo - W56 5-Speed Swap - Red on Red
'90 4Runner 2-Door - 3.0L 3VZ-E - Auto to R150F 5-Speed Swap - Red on Gray
'94 Supra Turbo Targa - 3.0L 2JZ-GTE - Marlin Crawler R154 - Imperial Jade Mica on Black
'89 Supra Turbo Targa - 3.0L 7M-GTE - Marlin Crawler R154 - White Package on Blue
'89 Pickup DLX 2WD - 2.4L 22R-E - W55 5-Speed - White on Blue
02-13-2009, 06:44 PM
i have tried to pry the clear part off but it seems to be stuck i figured it would come apart there but it almost seems sealed together any suggestions
02-14-2009, 12:15 AM
Umm...not really. ChildrenOfBodom has it correct. I had to kind of force mine to come down and it was slightly difficult to remove the lens.
Check out my garage.
02-14-2009, 12:36 AM
Real Name: Taylor
Real Name: Taylor
they have a rubber trim on them, but nothing that should stick. give em a little force and see what happens
there is a small peg that sticks out of the housing into the clear plastic to keep it aligned properly, but it shouldn't stick at all
02-15-2009, 09:51 AM
Real Name: Joe
Real Name: Joe
Ya, the guys previous posts are correct. When you don't have to mess with things, that's what happens. Try a little WD-40 that always helps. I suggest WD-40 a lot!
2012 Nissan Maxima SV Premium/Tech. Package Winter Frost Charcoal Leather
2011 Toyota 4Runner SR5 4x4 Blizzard Pearl Graphite Sport Cloth(4.0 Liter V6)
1966 Mustang Coupe (5.0)
02-15-2009, 10:56 AM
it really was that simple i just started pulling and finally they came apart it was really easy the lenses were completly caked with dirt on the inside so i cleaned them up and bought new lights then put em back in.... now only if i could fix that messed up 3rd brakelight
11-25-2010, 01:10 AM
does this work for 1984 as well. i couldnt get mine out the other day either
11-25-2010, 02:36 AM
Jason you should've just bought a new one like the hypnotic one that Brian has back there.
2000 4RUNNER SR5 TRD Supercharger, OME 882's w/ topout's and n91sport strut up front.OME 851's w/ cones and trekmaster LC shocks in the rear. R.I. LED lighting, retrofit E locker, 1" diff drop, 315/75/16 cooper discoverer STT, 2" R.B. body lift, rear disc brake conversion, Ingen intake, Spectre cone filter, Fitch fuel cat, Cobra LTD29 CB, custom front, and rear bumper, smittybuilt 8000 # winch, 66" 4xinovations rock sliders w/kickout, lil skip's gas tank skid. Custom skid plates. My build thread is @ http://www.toyota-4runner.org/3rd-ge...ld-thread.html
11-25-2010, 05:06 AM
Mine is rad. You had to stare at it for 25 miles back from Fawnskin, haha. You are getting sleepy...
2021 Tacoma 4x4 TRD Off Road Double Cab Short Bed (my DD)
2017 4Runner 4x4 Limited (the wife’s)
11-25-2010, 10:03 AM
LOL follow the light, follow the light.
11-25-2010, 11:51 AM
im telling you those will make perfect rock lights. i love how its so bright you cannot see your plate with all the glare
11-25-2010, 02:40 PM
It seems like people don't tailgate me at night anymore, I wonder why? Now I just need to stick a Hella 500 back there for when they do.
11-25-2010, 02:49 PM
i have an ipf 986 you can use lol
