09-22-2016, 03:01 PM
#16
You can always use a volt meter and see if there is power to the socket. Stick a brick or something on the brake pedal and check it.
The old bulb should have a number on it..
09-22-2016, 03:52 PM
#17
Oddly enough...the bulb I pulled out of the truck (I'm the original owner) was a 921 size bulb....but no numbers/letters on it anywhere.
12-13-2016, 10:14 AM
#18
Did you ever find a replacement for this part? I also have an issue with that part its burnt... ive been pulled over twice now but I was given a warning... please let me know.
12-13-2016, 10:15 AM
#19
Originally Posted by slimboiphat
Bringing this thread from the dead!
Does anyone know the p/n to the 3rd brake light housing(?) in the pic below? It says KOITO E4-2. Thanks in advance.
12-13-2016, 11:43 AM
#20
It should be 81570-35040
1997 4Runner Limited V6 Auto 4x4 w/E-Locker - 184K Miles
OME 881/890 Springs, Tokico TrekMaster GU3535/GE3536 Shocks, 1" Front Diff. Drop, Front Frame Mounted D-Rings
All-Pro 1.25" Hubcentric Wheel Spacers, 265/75R16 ETS Trail Master M/T, B&M 70268 Cooler (bypassed)
2010 Matrix XRS 2.4L 5-Speed - 130K Miles
12-15-2016, 12:37 AM
#21
thanks a bunch!
1993 Honda Accord EX | 5 speed
2000 T4R Limited | TRD SC w/ URD 7th injector and factory rear diff lock
1994 T4R SR5 | 5 Speed 4WD SOLD
2007 Subaru STi | Stage 2
06-10-2017, 05:29 PM
#22
Official Vendor
Official Vendor
Factory bulb is Koito 18 watt. Just changed my original bulb after 20 years! ANd it was deformed. This bulb being burnt out made my truck shift erratically (triggers torque converter lockup) when puttin the turn signals on in the final drive gear at highway speeds. If this bulb burns out, beware of this.
For 4Runner/SUV Accessories, please visit www.burtmanindustries.com
My 4Runner website
https://www.youtube.com/user/burtmanindustries, New YouTube channel! please subscribe and I'll make more videos!
[email protected]
DO NOT PM - text/call 717-319-2100 (24/7)
02-22-2020, 11:24 PM
#23
Bulb
These are great to replace the bulb, but does anyone have an idea for how to change it to something better? Maybe an LED option? Thanks!
10-20-2020, 04:29 PM
#24
Bringing back this dead thread again to see if anyone has actually changed out the third brake light for a LED without any issues as I am in the process of switching to LEDs on everything. Thank you.
02 T4R SR5 3.4L AT 215k - TJM Front Bumper - Coastal Offroad Rear Bumper - 914Z Ditch Lights w/ CBI brackets - Ebay Snorkel - Airaid MIT - Big 4 - B&M 70268 - Complete Suspension Rebuild - OME 881/906 Coils - OME 90004/60028 Shocks - ToyTec 1" BL - SS Diff Drop/Panhard Bar/Rear Body Mounts/Hi Lift Mount. Plus other stuff.
10-20-2020, 05:13 PM
#25
You just need to have load resistors in the brake light system to make sure the other systems that rely on the signal to work correctly. Put a load resistor with each brake light (on the sides) and you won't need to worry about the 3rd brake light bulb type.
It will likely be difficult to find an LED bulb that will have the right beam pattern to work exactly like the stock 921 though... (it comes into the housing at an angle, if I remember correctly)
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
10-20-2020, 07:19 PM
#26
I just replaced mine the other day with this: Amazon.com: LASFIT 921 912 W16W LED Third Brake Center High Mount Stop Light Bulbs, Red Light, Plug&Play: Automotive
Lights up plenty bright now since mine looked like the one Jason B posted above.
2000 SR5 Sport - 4EAT and E-locker, King 2.5s, EimKeith PCK, SPC UCAs, 33" KO2s on Black Rhino Boxer gloss gold 17x8.5, Savage/Lotus skids, 4xInnovations front bumper/sliders, Shrockworks bumper & tire carrier, Lil Skip Gas Tank Skid, Magnaflow Overland cat back
10-20-2020, 11:48 PM
#27
Originally Posted by Twan
Excellent. Thank you. I will be ordering this.
10-21-2020, 12:00 AM
#28
I replaced the two brake lights with LEDs and havent had any issues yet. I know i need to get a relay for the blinkers to prevent hyper flashing but what would the benefit of putting load resistors on each brake light be?
10-21-2020, 12:24 PM
#29
The brake light circuit needs low resistance in it for the ABS system to sense the brake circuit correctly. One incandescent is enough - and since people replace the third brake light last, they blame problems on that. It isn't specifically the third brake light, all three are directly connected. You just need sufficiently low resistance in the circuit *somewhere*. I suggest doing it down by the tail lights because there is more room/access to put a load resistor there.
10-21-2020, 03:15 PM
#30
Real Name: Blair
Real Name: Blair
I just noticed my original 3rd brake light bulb is out. If I have standard bulbs in the main brake lights, I can use an LED as a 3rd without any other resistance mods, right?
258K - Y2K/E - Clock still works
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
