Old 03-09-2009, 12:29 PM #1
jim77446 jim77446 is offline
jim77446 is an unknown quantity at this point
Transmission oil change on 97Rnnr 2WD
Hello All,
I have 97Runner with 110K miles. Last transmission oil was done at 60K and now the fluid is brownish. I like to do the oil change myself to save cost.
Are there any pictures available to guide me how to change the oil?
How much oil is needed?
what parts need to be changerd?
The dealership tells me 12 qts and filter. I am supposed to have metal filter. I like to know how much additional oil is needed to get all the dirty oil out.
Any guidelins will be very helpful.
Thanks,
Jimm
jim77446 is offline   Reply With QuoteReply With Quote
Old 03-10-2009, 11:42 AM #2
Folks,
Am I in the wrong forum? or my question is not the right question? Can anyone point me to right forum where I can get transmission questions?
Thanks
Old 03-10-2009, 11:59 AM #3
3000 FPS 3000 FPS is offline
3000 FPS is an unknown quantity at this point
I pulled the pan on my 2000 4runner and drained the transmission fluid and changed the filter. I did not do a flush like what you are talking about doing. I believe I only lost about 3 or 4 quarts of fluid when I filled it back up.
3000 FPS is offline   Reply With QuoteReply With Quote
Old 03-10-2009, 05:48 PM #4
pat161's Avatar
pat161 pat161 is offline
pat161 is on a distinguished road
pat161's Avatar
Couple things here, you don't need a new filter, your truck uses a metal screen which can be cleaned w/ brake cleaner and then reinstalled. Some do buy a new one as they seem fairly cheap, but not needed. To access the filter you will need to drop the pan, while in there you might as well remove and clean the magnets, make sure you put them back in though. While dropping the pan you will need to split the dipstick tube in half, half stays with the pan half comes off, there is a rubber o ring holding them together and it can be a PIA to split them, make sure you remove the dipstick first. To reassemble all you will need is some RTV sealant as the tranny pan does not use a gasket per se and new fluid. Be careful torqueing the pan bolts, they go into aluminum and will strip easily.
Now if you want to purge all the fluid you will either bring it to someone w/ a flush machine or you will locate the lines running to and from the cooler, which is in the lower radiator. Then you will simply take the line running to the cooler, dirty fluid, and put it in a empty bucket, take the return line and put it into fresh fluid then run the truck. You will see old fluid go into the bucket and new fluid will get pulled into the tranny. Do that until it comes out bright red.
Either way I recomend pulling the pan and cleaning the filter and magnets. For a drain and fill w/ pan drop I was able to get 5-6 quarts, just plug 4-5 complete flush IIRC is more than 12, closer to 15 plus a little extra to run through.
pat161 is offline   Reply With QuoteReply With Quote
Old 03-11-2009, 06:30 PM #5
004Gunner's Avatar
004Gunner 004Gunner is offline
Registered User
004Gunner is on a distinguished road
Registered User
004Gunner's Avatar
Just wanted to add that synthetic fluid is great and would recommend it. I had a flush done with synthetic at 62k miles and was told it was good for 90k miles. At 120k miles the fluid was still bright red so I plan on taking it to 150k. The pan and drain plug are easy to find though. It's straight back from the oil plug and you will see the rectangular aluminum pan. If you crawl under the car from the driver side door it should be just about straight up. Any doubts, just remove a bolt and see if it bleeds red, or your case maybe a brownish red
004Gunner is offline   Reply With QuoteReply With Quote
Old 03-12-2009, 10:53 AM #6
spongerx's Avatar
spongerx spongerx is offline
Real Name: James
spongerx is on a distinguished road
spongerx's Avatar
Real Name: James
004GUNNER, what brand syn tranny oil did you use? Need to do mine pretty soon.
1997 SR5 5spd
SS 1.2 - Deckplate - MT Classic II's
ISR - True Flow - Magnaflow - 285/75 BFG AT
spongerx is offline   Reply With QuoteReply With Quote
Old 03-13-2009, 05:20 PM #7
004Gunner's Avatar
Registered User
Registered User
004Gunner's Avatar
I had it flushed at a meineke (I know, I know) but a friend recommended one of the guys there because he was straight up and would tell you when something was not needed. They used BG fluids and I am definitely impressed with it. I think it is only available commercially though so my next change will be Mobil 1.
Old 08-19-2009, 02:47 AM #8
texas_runner's Avatar
texas_runner texas_runner is offline
texas_runner is on a distinguished road
Originally Posted by jim77446 View Post
Hello All,
Thanks,
Jimm
according to my owners manual the fluid level for a drain and fill on a 2wd is
"Up to 1.7 qt"
texas_runner is offline   Reply With QuoteReply With Quote
Old 08-19-2009, 10:55 AM #9
el-guapin el-guapin is offline
el-guapin is an unknown quantity at this point
Info about tranny fluid int the owners manual is incorrect. research this you will need anywhere between 3-4 quarts to drain/fill.
98 4Runner SR5 3.4L Auto...SOLD!
el-guapin is offline   Reply With QuoteReply With Quote
