Old 01-17-2020, 12:05 PM #16
TheDurk's Avatar
TheDurk TheDurk is offline
TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light
TheDurk's Avatar
Originally Posted by zacktshields View Post
Disconnected the positive battery cable for 30 seconds and worked for me on my 2016 4runner trail edition
Originally Posted by werk71 View Post
if you disconnect battery drain power from vehicle after disconnect by turning on lights and stereo to drain out all power stored. i build tuner cars and do this alot.
In this day and age, there is no excuse for not owning an inexpensive Bluetooth code reader that will do the reset AND give you the code.
My Backyard Frame Swap
Old 01-17-2020, 08:25 PM #17
werk71's Avatar
werk71 werk71 is offline
werk71 is on a distinguished road
werk71's Avatar
i use a cheap 375$ one. but just resetting the light doesnt set fuelmaps and spark plug voltage back to stock maps. some times fuel maps and voltage maps get re wrote so many times depending on what you cars health is it needs reset all the way. inexpensive readers dont always have features, some just read and cant write, if you get one make sure it can actually write then you'll be in better shape with this stuff.
IMG-3745-1
werk71 is offline   Reply With QuoteReply With Quote
Old 01-18-2020, 02:00 PM #18
TheDurk's Avatar
TheDurk's Avatar
ALL the Bluetooth adapters will write, assuming you use the Torque Pro app on it, which is the way to go. They will also live scan and do just about anything that fancy one will do, and with a much better screen if you have a tablet. You probably can do much more. Torque is really only limited by what the CAR can do over OBDII; if the PID is there, Torque will display it, graph it, alarm it, or whatever. Cheap wired adapters, whether they write or not, really have no place in the modern world unless you just can't figure out how to use a smartphone app.
Your point about the maps is valid, assuming you DO want to reset those.
Old 09-30-2020, 03:26 PM #19
bko4488 bko4488 is offline
bko4488 is on a distinguished road
Isn't it recommended to always disconnect the negative terminal first?
bko4488 is offline   Reply With QuoteReply With Quote
Old 09-30-2020, 08:57 PM #20
Endlessblockades's Avatar
Real Name: Blair
Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold
Real Name: Blair
Ancel and other basic OBDII reader/clearing devices are super cheap. I got one for $20 and can hand it off to any friend that wants to read and clear codes. It's floating around with whoever needs it. That's the only 'advantage' over the app-driven BT devices - some of those are pretty awesome. Killing all stored data with a power drain seems like overkill and not knowing CEL code the engine is throwing is borderline negligent. I also feel my rig has programmed a nice EFI path and paired with a performance muffler and air filter are good for nearly +2HP
Amazon.com: Code Readers & Scan Tools - Diagnostic, Test & Measurement Tools: Automotive
Old 10-02-2020, 03:38 AM #21
Real Name: Blair
Real Name: Blair
One more option - an Ultragauge can read and write over CEL codes as well and it gives me a chance to show the Spiker Engineering bracket I installed tonight doing it's thing....the stock handhold mounting screw that holds the bracket in place actually came out without a messy extraction due to the thread-locker Toyota used (cordless drill on slow with clutch off and pushing hard with a brand new bit). YMMV.
Reset check engine light-3-jpg  Reset check engine light-2-jpg
Old 10-02-2020, 10:47 AM #22
Roger.klotz Roger.klotz is offline
Roger.klotz is on a distinguished road
The Scanguage 2 might clear codes as well.
Roger.klotz is offline   Reply With QuoteReply With Quote
Old 10-03-2020, 10:56 AM #23
TheDurk's Avatar
TheDurk's Avatar
Absolutely, unless it's a 6V positive ground 1955 Ford pickup.
