Originally posted by rjyhdc4
If you read my post I stated "If you can't find the actual drain." In addition, I wouldn't want to remove a fuse and replace it every time I need the dome light...
I did read your post... and he hasn't been able to find the actual drain yet, so he's pulling the fuse. As for what he does in the future, like I already stated, your suggestions aren't a fix, they are just a temperary band-aid, which are similar to what he's already doing.
Besides, if you wouldn't want to remove & replace a fuse every time you needed the dome light, then I'm fairly certain you wouldn't be happy disconnecting the battery every time you needed the dome light either.
