03-30-2009, 04:45 PM
starter replacement 3.4 4wd
Well guys, I had the unpleasant experience of changing the starter on my truck today. Thought I'd share some tips to make it easier for you.
Tools needed:
3/8 drive ratchet
12 to 16" extension
10, 13, and 14 mm sockets
12 mm wrench
As always, disconnecting the battery is step one.
Step 2:
remove the 12 mm bolt holding the transmission dipstick tube to the head and remove tube.
Step 3:
remove the 14 mm drain plug from the trans. pan and drain fluid.
step 4:
using a 1/4 drive and extension, remove the 10mm bolts and drop the transmission pan
Step 5:
remove the black plug going to the starter solenoid and remove the battery cable from the starter (13mm)
Step 6:
using the long extension with a universal joint and 14 mm socket, remove starter bolts
Step 7: once the starter is loose, take the 12 mm wrench and remove the power steering line from the rack and pinion. The will allow room for the starter to be removed.
Installation: reverse steps.
I recommend changing out the transmission filter whille you have the pan off. I tried sEveral different methods of removing the starter and this one was the easiest. The Haynes manual says you can remove the starter through the wheel well, this is not true! GOOD LUCK!
'99 "Big Boy" 4Runner SR5 4wd
ARB Bumper/ SmittyBuilt winch/ Hella 500's, Roof Rack,Deck plate Mod/ ISR mod/ TRD "O" TB gasket/ K&N air, FlowMaster,3" Toytec front, OME 851 LC 2" lift coils rear, extended length LC shocks rear, diff drop, Toytec brake line extension, Definity Dakota M/T LT265/75/16 tires,Lowrance GPS, Kenwood head unit, Sony Xplode 4 channel 800 watt amp, rear Stealth speaker box w/ 10" JL sub, backlit Inclinometer, Cobra 19 CB, TRD Off Road decals
03-30-2009, 05:39 PM
Super Moderator
Super Moderator
That is a good write up. I heard it is a bear to change the starter.
2001 & 2004 Toyota 4Runner SR5 4X2
Both V6 and both Natural White
"Yeah, I like white and I like 4Runners"
03-30-2009, 06:19 PM
Does that include for a manual?
03-30-2009, 09:00 PM
A manual is going to be a little easier, you don't have the Transmission dipstick in your way.
Shawnstcyr, you did this nitty gritty pain in the ass way. The transmission pan for future referrence does NOT need to be removed. I see your idea in going parallel with the exhaust pipe and down out from the rack and pinion but that's too much unesscessary work. If you wiggle the starter you CAN get it out through the wheel well.
03-30-2009, 09:30 PM
Tried it first. Wasn't gonna happen. I even undid the bracket holding the brake line from the ABS pump. No luck. Keep in mind this was an outdoor repair. Also, the filter needed servicing anyway. Maybe there are some minor differences on your 4Runners. This was the most pain free method after an hour of twisting and studying the situation.
03-31-2009, 01:13 AM
As long as you figured it out that's all that matters. Everytime I do these starters even though I've done a few there always seems to be the fair share of F bombs haha..
07-21-2013, 09:09 PM
Thanks for the advice. It was a pain in my side for the past 24 hours. Could not break the bolts free - had to let them soak with PB Blaster for about 20 hours.
I hope to never do this again.
07-22-2013, 12:25 AM
I read up a lot before I did the starter swap on my 1999 v6 5spd and the last write up I read said take your time and don't make it harder than it is, engineers did build this truck. I talked to a Toyota tech afterward and he uses a flex extension to get at the starter bolts (Might even remove the exhaust manifold)--me I used a standard wrench and not a ratchet. It's tight but it worked. Surprised the tech.
07-22-2013, 08:34 AM
Real Name: Robert
Real Name: Robert
The starter on my '99 was a total b!tch. I tried changing it in a gravel parking lot, at night, without all my tools I usually have. Needless to say, it didn't go well.
1999 Toyota 4Runner Limited 4x4 - Turbocharged Garrett 57-trim T3/T4 - URD AFR Sensor Calibrator - DW255 fuel pump - 7MGE Supra 315cc “lime green” fuel injectors - 231mm Tundra Brakes - B&M 70264 Transmission Cooler - Monitoring ATF Temps and AFRs With My iPhone - DIY Projector Headlight Retrofit - Cooper Discoverer AT3 - OME 906 Coils & Rancho 9000XL Shocks (Rear) - Airlift 1000 - RadioShack $5 Rear O2 Simulator
2000 Yamaha XR1800 Jet Boat - MR1 4-Stroke Engine Swap
07-22-2013, 12:57 PM
Wow, that sounds like a lot of work for a damn starter. I hate when 'easy' tasks are super complicated becuase you need to remove 900 parts to get to what you need to fix.
Dropping tranny pan to change a starter??? SHeeeeshh.
85 Xtracab, 3Link Front, Marlin Dual Ultimate, Double Locked on 37s
08-08-2013, 09:25 PM
No need to drop the pan...
Remove Pass wheel.
Remove dipstick.
Remove brake line bolt.
Remove exhaust hanger bracket.
Remove starter bolts & wires.
stop.. sip beer....
Take starter out from side (it is a square ped round hole deal, but it will come out).
No need to replace the whole starter, just replace the starter contacts (~$10-15 at any local electric motor repair shop)
There's plenty of tutorials on this forum that go into way more detail. Also videos on the ole you tuber.
New Rig:
2008 Tundra 4x4 Crewmax Limited
Old Rig:
1997 SR5 3.4L Auto 4x4, Over 300k miles...
05-13-2015, 10:07 PM
I'm having trouble removing the upper part of the transmission dipstick, any tips?
05-14-2015, 12:32 AM
What are you having trouble with? Is the bolt holding the bracket not coming loose? Remove the dipstick first so you dont damage it. Unbolt the bracket (i think its a 12mm if i remember correctly). Then just pull and twist the upper part of the filler tube out. If the bolt wont come loose just hit with some penetrating oil and wail 15min then try again.
05-14-2015, 12:43 AM
Real Name: Scott
Real Name: Scott
I don't understand why you have to remove all this stuff in the original post. When I removed mine to replace the contacts, it came out of the wheel well after a bit of twisting. It was out repaired and in in under an hour
05-14-2015, 12:53 AM
Dropping the swaybar out of the way was easier than the wheelwell on mine.
There's no way I'd consider dropping the trans pan.
