05-26-2009, 08:15 PM
Should I Replace Headgasket or Dump
I have a 1997 SR5. 144,000 miles. I am third owner. I have maintained well, but previous owner did not, as much. Exterior rough. body good. Engine seems fine.
Car has overheated twice recently. 1st time after about a 30 mile drive. Took dealer two days to determine it was the thermostat. Drove it local, a few miles here and there for about 2 weeks. Then drove the same 30 mile trip last week, over heated again. Now the dealer says it's a blown head gasket.
I have two questions:
1) Any thoughts on whether this dealer is wrong, right, etc.?
2) If it is the head gasket, any thoughts on whether it's worth replacing. They say it will be about $2K. That's about what sites list for the year and mileage.
Any comments welcome.
Bill - Philadelphia
05-26-2009, 09:12 PM
Re: Should I Replace Headgasket or Dump
I'd have taken the 4Runner to a local mechanic (especially the ones who specializes in Toyota's vehicles.) Based on what you said, it sounds like the Dealer's guys have no idea what they're doing and they are trying to squeeze every dollar you have out of your pocket. Just go to a local mechanic and see what they say. If it's similar to what the Dealer said then I'd check prices for both to see which one is cheaper to fix
2018 4Runner Blizzard Pearl
05-26-2009, 09:16 PM
I would check the radiator first. It may be plugged, and it's WAY cheaper to replace than a head gasket.
This same thing happened to my brother-in-law on his T100 (same engine). They replaced the head gasket and it still overheated. They replaced the fan clutch and it still overheated. Then the replaced the radiator and all was good!
05-26-2009, 09:26 PM
yes, usually a good idea to check the simple things like a thermostat or rad first before looking at head gaskets etc.
05-26-2009, 09:32 PM
Start with the cheap stuff, but if you already have overheated the engine, the head gasket and head work will be needed.
The "blown head gasket" they are quoting you for is probably replacing the head gasket and resurfacing the head because it will most likely be warped from the multiple overheating incidents.
No matter what, take it to a private shop (because of the age/ condition) and hopefully you can find one that is moderately priced.
Good Luck
1997 Desert Dune 3.4L V6 Auto 4WD
Shrockworks Front Bumper - PIAA 510 Fog & 520 ATP Lights - Savage Off Road Rear Bumper - BudBuilt Front & Belly Skid Plates - Stubbs HD-SKO Sliders - 265/75r16 BFG All-Terrain T/A KO Tires
05-26-2009, 11:07 PM
Real Name: Bryan
Real Name: Bryan
Don't just start throwing parts at it. That's just expensive and rarely fixes the problem.
Pressure test the radiator first. If all good, do a leakdown test on each cylinder. If you find two adjacent cylinders are leaking more than specs, there's your blown head gasket.
Millennium Silver 2001 4Runner SportR5lander
Photo Timeline - Solid Axle Club
All-Pro, Fox, Eibach, OME, Goodyear, Trail Gear, Yukon, Solo Fabworks, Marlin, TJM, Smittybilt, Front Range Offroad, Inchworm, Addco, Savage Offroad, B&M, Borla, Pioneer, Cobra
Northeast 4Runner Owners Association
05-26-2009, 11:32 PM
another easy test you can do is to test for exhaust gas in the coolant, Napa has a kit for this, that is something you can do at home w/ out having to trust a shop/dealer.
If it is a blown head gasket, then post some pics of the 4runner so we can get an idea of what kind of shape to know what its worth.
05-27-2009, 01:49 AM
I would second both comments by LINY 4Runner and Stick Figure. The test for the exhaust gas and leak down are both used in the shop I work in to confirm a blown head gasket.
Can't beat the Cental Coast!
'97 SR5 v6 4x4 Desert Dune
Tundra Brakes, Sliders
05-27-2009, 07:53 AM
Thanks
All...
thanks very much for this info, much appreciated.
The dealer did do a pressure test after original event. So that should have been/be fine. We'll see.
Thanks!
Bill
Bill - Philadelphia
