06-19-2009, 09:16 PM
Real Name: James
Real Name: James
Pioneer Install
I'm doing an install of a Pioneer HU and I'm wondering what these two wires are. I'm assuming the bigger one of the two is the antenna. But what is the smaller one? It is grouped with the bigger wire and runs in the same direction back into the dash. But they is no place to insert it in the new HU. Any ideas?
1997 SR5 5spd
SS 1.2 - Deckplate - MT Classic II's
ISR - True Flow - Magnaflow - 285/75 BFG AT
06-19-2009, 09:22 PM
They are both antennas. There are 2 antennas, regular and diversity, i think. But don't ask me why or what the difference is even though I should know seeing as I'm studying EE.
I'm pretty sure most after market units will only take one of the antennas. When I put in my pioneer, i just used the one that fit and called it good. Radio reception is fine.
I would also recommend installing a switch in the antenna signal line. Unlike the factory radio which only raises the antenna when the radio is on, pioneers raise the antenna whenever the HU is on which is annoying. With a switch, keep it off and the antenna never goes up. Then just flip the switch when you want the radio.
2001 SR5 4WD Millennium Silver
OME 882/890
Pioneer DEH-P5000
Hella Micro DE Fog Lights
Profit/Proclip iPhone mount
06-19-2009, 10:14 PM
Registered User
Registered User
The diversity antenna is embedded in the the rear glass on the passenger side. Someone on here posted about an adapter that allows you to use both the plugs which gets you better radio reception. I'll try to find it. . .
Ok here it is and hope this helps even though this is on a 4th gen. Click
06-20-2009, 01:17 AM
Real Name: James
Real Name: James
Thanks you guy's. Interesting...
Well, it turns out I have another issue. Apparently I have a factory amp which requires a different kind of wiring harness. By different I mean NOT the one that came with the HU. Oh well. I'll have to wait till tomorrow to install, that's if someone in town has the correct harness. Will update when complete.
1997 SR5 5spd
06-20-2009, 01:50 AM
Real Name: Taylor
Real Name: Taylor
check ebay for that harness to go with the factory amp. i got my new harness for like, $5 plus a little shipping.
you can take the amp out if you want, but your speakers get waaaay more power with it in. its worth it
06-20-2009, 03:14 AM
i had the same problem w/ the amp. just unplug it, remove it and i promise everyrthing plugs right into pace.
your new HU probably displaces more power than the stock amp anyways.
2001 4runner, 4wd
ICON extended travel coilovers.Camburg uniball upper control arms.
toytec diffdrop.OME 890's rear.
Flowmaster Super 40 w/ turn down tip. BFG mudders 285/75-16.
06-20-2009, 03:18 AM
ditch the factory amp all together any after market cd player will have more than enough power
98 4runner sr5 3.4L 5spd 4x4 e-locker sold 10/2/11
07 tundra 5.7L 4x4 limited dc was my moms r.i.p 3/19/11
Oregon Toyota Owners Club
06-20-2009, 06:50 AM
Registered User
Registered User
Agreed with not using the factory amp. An aftermarket hu will supply between 40 and 50 watts per channel which is definitely more than your factory amp supplies. When I changed out my factory radio for an aftermarket hu, I noticed a huge difference in my factory speaker output. What I don't know is whether or not one of the antennas would get a power boost from the factory amp.
06-20-2009, 09:54 AM
Real Name: James
Real Name: James
Thanks everyone for all the feedback. I'm working all day but I'll look at removing the amp when I get home. I guess that you can only use one or the other, not both the amp and the HU's power?
1997 SR5 5spd
06-20-2009, 11:36 AM
x2. Just replacing the head unit with an after market one made my speakers sound brand new or even better. Once I upgraded from OEM speakers to Infinity ones, the difference was even more noticeable and it sounded great.
'02 Limited 4WD
Stuff:OME 3"|ARB Tacoma|Light Racing UCA's|Savage KO sliders|285/75 Terra Grapplers|TRD catback|TRD wires|Brembo'd|VVME 4300K HID|LightForce 170|Exterior LEDs||Inside: Infinity Comps/Kicker/Nuvi625WT|Uniden 520XL|15% tint|Full LED swap|Backup camera
Pending Install:LC80 wheels,OME 883 and LC 8 wraps,panhard drop
06-20-2009, 06:22 PM
Yep, you just need to bypass the oem amp. And in case, your new wiring harness still doesn't work, stop by your local Best Buy store (if you have one in your area) or any car audio shop. Those places sell universal toyota aftermaket wiring harnesses.
BTW, what model HU you installing?
2002 4Runner Sport 4WD
Headlight Adjustment
"Live life w/o Limits. Your imagination is not limited by time or distance, by logic or by scarcity. You can fill your imagination with whatever you choose."
06-21-2009, 12:41 AM
Real Name: James
Real Name: James
Ok lads. I pulled out the amp and got everything back in like you said. Thanks for your help. I installed a Pioneer DEH-P6000UB. I'm really stoked so far. I've never bought a new HU before. I am having a hard time trying to fine tune the EQ to my liking so that will most likely be a long process. So far I can't get the bass how I want it. Oh well. Gotta start somewhere.
1997 SR5 5spd
06-21-2009, 05:12 AM
it was easier to do than to picture doing it after reading, right?
way to go dude. good luck with your settings.
2001 4runner, 4wd
06-21-2009, 09:14 AM
Real Name: Bryan
Real Name: Bryan
My pioneer HU doesnt do this...It's actually got a wire for power antenna, as do (IIRC) most other HUs these days
Millennium Silver 2001 4Runner SportR5lander
Photo Timeline - Solid Axle Club
All-Pro, Fox, Eibach, OME, Goodyear, Trail Gear, Yukon, Solo Fabworks, Marlin, TJM, Smittybilt, Front Range Offroad, Inchworm, Addco, Savage Offroad, B&M, Borla, Pioneer, Cobra
Northeast 4Runner Owners Association
06-21-2009, 04:54 PM
my power antenna broke along time ago i replaced it a few weeks ago with a tacoma whip works way better now
