06-24-2009, 10:54 AM
Sway-Bar End Link Bushings
I just replaced my front sway bar bushing, wow what an improvement. Now I want to replace the rear bushings and front and rear swaybar disconnect bushing but am having a hard time finding them as a kit. Can anyone help me out here? Pepboys and Autozone said they are special order. I would like to get the urethane bushing is possible.
Thanks
Bob
1997 Toyota 4Runner Limited
3.4L, Auto, 4x4
1997 Toyota 4Runner Limited 3.4L
Mods: Deckplate, ISR, Various LEDS
Exhaust: Magnaflow Cat and Muffler
Susp: 3" Toytech w/LC Coils, 285 AT2s
06-24-2009, 11:35 AM
Registered User
Registered User
second that request
I too would like to know...where did you get the parts/kit for front? $?
thanks
06-24-2009, 12:33 PM
bushings
this site will tell you everything you need to know
http://www.top4runners.com/ja/es.html
2000 4Runner SR5 V6 4X4 auto
TRD ceramic coated headers, DRL lights turned off !!, Royal purple fluids, Toyota Tranny cooler,silver star headlights, PIAA HID corner lights, Hella fog lights, LED Tail lights, PP1 springs Bilstein shocks, Addco sway bars F/R, EBC Rotors & Pads, Gloss black calipers, Russell SS brake lines, urethane steering bushings, Nitto Terra Grapplers on Black Rock Viper wheels, Air elbow mod, Deck plate mod, Rear diff breather mod, Inline weather guards****** Friend don't let friends drive stock ******
06-24-2009, 01:27 PM
Registered User
Registered User
he's right
my 401 friend is correct, I already had that in my faovrites too.
06-24-2009, 01:54 PM
That helps me find the rear sawbar bushing. Now I need the front and rear end link bushings. Can you buy them seperate?
06-24-2009, 03:26 PM
What gains do you get from this mod? Just non squeaky bushing? It looks very cool and probly not a bad idea to do it. I was just wondering. Thanks
2002 SR5 4WD
deckplate + ISR, Airlift 1000, OME 881/890, Goodyear Wrangler Duratrac 265/75/16C
Tundra 231mm Brakes - yes they DO fit the stock 5 spoke rims - Stubbs Welding HD-SKO sliders.
06-24-2009, 03:39 PM
I'm just trying to replace worn out parts. Steering and stabilization will be better after the repairs.
06-24-2009, 04:29 PM
bushings
You should be able to go to your local automotive store and buy urethane bushings there for the links themselves. When installing urethane bushings bushings make sure to apply a generous amount of water proof marine grease. or you will start hating your drive do to the binding noise of urethane. also this mod won't do that much unless you have the Addco sway bars. I would suggest waiting and doing it all at once and defiantly get the greaseable bushings!!!! Also sense I don't do that mush off roading I bought the Addco sway bars these are much thicker than stock and make a huge difference in cornering. near flat around corners. I will post a link to what you will need for this kit because addco send you the bars but there are many other small things you need to do to maximise your gains!! I must say that between these two mods my 4Runner drives and handles amazing!!! also make sure you buy new factory links. man things add up fast. but well worth it
http://www.top4runners.com/ja/addco.html
