11-18-2010, 07:36 AM
#61
215000 on my 99 limited. still runs great. hard to beat.
11-26-2010, 12:19 AM
#62
260,000 on my 99 SR5 4WD. I've owned it since 76,000 miles. No leaks and drives great. Gets Mobil 1 synthetic every 10K, air filter every 20K, timing belt and water pump every 90K....and transfer case/rear end oil change every so often(when I feel like it)
I've replaced the exhaust, one starter, two sway bar end links, one coil-pack, two sets of plug wires. I used all OEM parts.
Hopin it makes 300,000!
1999 4WD 4 Runner
11-26-2010, 02:20 AM
#63
Just bought my 2000 SR5 automatic two weeks ago. I'm the second owner - original was an anal engineer-type(like me)who did all his own maintenance, mainly fluid changes. Had a water pump and belts done immediately, as it was due. Last week brought a dead battery, which I discovered was the ORIGINAL Toyota item. Only other work done was brakes and shocks. Mileage? 289,000, and the truck is as tight as new. This is my third T4R. Total miles for the three is more than half a million.
11-26-2010, 09:53 AM
#64
Just bought a 98 4runner SR5 4wd with 147,000 miles and it runs like new. It looks like it still has the original timing belt which I will be changing soon.
11-26-2010, 01:21 PM
#65
Miles
My 1992 4Runner SR5 V6 had 498,000 miles on it. I maintained it religiously, outside and inside. The headgaskets had been replaced three times. My current 1998 4Runner Limited has 162,000 and has had 0 problems.
COMO CHINGAS OFF ROAD
AAT: Senior Trail Advisor, Lower Larga 2N06X - USDA Forest Service
11-27-2010, 11:09 PM
#66
I have a 1996 4Runner SR5 with 377,000. The engine is very strong.
11-28-2010, 12:32 AM
#67
A Toyota tragedy
98 4runner v6 auto 4x4
2nd owner
My camshaft threw a bearing at around 178k, and rebuilt the motor from a 5vze with 79,000 miles.
'98 SR5 V6 4x4 Sunfire Red
'87 SR5 Pickup Extra Cab 22rte 4x4 Cypress Green
Build Thread
11-28-2010, 04:26 PM
#68
Real Name: Rob
Real Name: Rob
I just hit 377k in my 96! Nice!
11-28-2010, 04:46 PM
#69
Just turned 147k on my 2000 3rz still on original clutch and brakes!
11-29-2010, 02:55 AM
#70
I'm on 165,800 and the clutch just started slipping this morning.
11-29-2010, 05:36 AM
#71
Mine is a 98 SR5 4x4. Just turned 170K this week.
Transmission started to show "clunking" recently when accelerating.
11-29-2010, 02:49 PM
#72
U joints?
4Runner Lifted/Locked/Armored/Blown
www.texaswheelin.com
01-13-2011, 02:19 PM
#73
2000 4x4 LTD w/ 258k miles and no sign of slowing down. I'm a little over half way to my goal!!!
2000 Limited Sports Edition, 285-75-16, TOYTEC Adjustable Front Coilovers, OME 891 & Bilstein 5150's rear, TOYTEC 1' Differential Drop, E-Locker, 4X4, 4.56 Gear Ratio, Tundra 231 Brakes, All-Pro Apex Front Bumper, OL Rear Swing-Out, 4X Innovation Sliders, Savage Offroad Skids300K, JVC Radio, Tacoma Whip, CB Radio
02-27-2011, 11:31 PM
#74
Real Name: Jerry Kraus
1998 T4R SR5 4x4 with 247K miles and still going strong!
Just make sure you change your fluids regularly and your timing belt on schedule. .
2002 T4R Limited 4x4 w/factory locker, factory supercharger, sunroof, deck plate mod, Tundra brake upgrade, BFG TA/KOs on 17" TRD rims, automatic transmission, 3" lift from Toytec with "Old Man Emu" heavy duty shocks & springs, 288,000 miles on it, I live outside Steamboat Springs, Colorado.
02-28-2011, 12:03 AM
#75
My 1996 with a 3.4 just hit 300k (valves rattle) But runs out strong
My 1997 with a 2.7 148k
Nitrous is like a Hot chick with an STD! You wanna hit it but your afraid of the consequences!
