02-09-2018, 08:14 PM
#31
Originally Posted by Wedgy
What is the purpose of the vent ?
Let's air out the back of the vehicle when the HVAC system is set to outside air and makes it easier for the doors to close. The one-way valve is so that the air from the back of the car doesn't come back into the car if the front windows are cracked, etc.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
02-10-2018, 01:07 AM
#32
That is sweet! New 2002 Sport owner here... definitely looking into this.
02-10-2018, 02:03 PM
#33
Thanks for the answer ! The only car I've seen that was hard to close the door with the windows shut was an old VW Bug. I swear those things would float.
02-10-2018, 02:47 PM
#34
how do you remove the back plastic panels completely from the truck with out having to cut it? I have been looking at mine trying to figure it out. I am going to gut my entire 4runner and most likely put newer seats in the front and re upholster the rear seats but keep the headliner, panels and carpet out and just dynamat some of the smoother flat surfaces this summer.
02-10-2018, 03:18 PM
#35
There is supposed to be a 1-way flap door on that vent (all recent vehicles have something similar). My truck was that way when I got it too...
You can still get the part new from Toyota.
Mine was missing the flap as well. I just cut up an old tile sponge to fit the hole. It does a great job of keeping the dirt out. It doesn't do that well against water though. lol
Only two things are infinite, the universe and human stupidity, and I'm not sure about the former. --Albert Einstein
02-10-2018, 07:30 PM
#36
What exactly was supposed to be in that compartment from the factory?? My sons has straps in there but nothing is in it..
02-12-2018, 04:11 PM
#37
It all comes right out. You need to have the back seats out first to make it easy (and you can see a bit of the dirt build-up I had in there before cleaning).
Nothing was in there from the factory on US/Canadian 4Runners.
02-12-2018, 05:07 PM
#38
In Brazil, the legally required warning triangle was strapped in that rack thingy in my '97 SW4 (Brazil market 4Runner). I guess you only get the triangle in countries that require it. Brazil also gets you a fire extinguisher under the front of the driver's seat and a first-aid kit in the glove box.
My Backyard Frame Swap
02-12-2018, 05:31 PM
#39
Hi guys,
I'm looking for a vent like that for a mod I'm doing to my first-gen (move the vent to the back). May I know dimensions, especially that of the opening where it inserts?
TIA.
86 4Runner, 22R-Eliable, 5-Speed Manual, dlx. WHAT'S YOURS?
If you want us to help from afar please let us see, hear, feel what you're dealing with.
A picture paints a thousand words.
Toyota components are bullet-proof. Issues often arise from poor wiring, assembly and/or maintenance. Suspect those first.
Next only to our senses, the multi-meter is the most important electrical diagnostic tool. Spend $6 at Harbor Freight or $$$ blindly replacing parts.
02-15-2018, 02:00 PM
#40
did you have to take the seatbelts off the I guess its the C pillar?
02-15-2018, 02:07 PM
#41
Is it possible to swap the quarter panel trim from a model with the larger storage compartment into my 98?
02-15-2018, 05:02 PM
#42
Yes, though it also requires some cutting of the sheet metal behind the panel. There has been a thread or two on here... search for it using a Google search with
Code:
site:http://www.toyota-4runner.org/3rd-gen-t4rs
in the search field with your search terms.
02-15-2018, 05:09 PM
#43
Code:
Tyler James Inc's OEM+ '97 Limited
- Tyler
Instagram - TF_Tyler
'98 LTD | Misguided and poorly planned
02-15-2018, 07:14 PM
#44
Real Name: Tony (no surprise)
I apologize if I missed it, but what is the general depth of this newly-found storage area, before the application of carpet?
One of my favorite automobile EDC bags (by Maxpedition) is to hefty for this spot, in stock form...
2000 Limited, E-locker
Maintenance/Build Thread
02-27-2018, 02:23 AM
#45
Bumping this thread since I just did this mod. I would estimate the area to be around 5" deep at its widest point. I didn't seem to gain much depth by removing the black liner, but gained a fair amount of room towards the front/rear of the vehicle.
6162A084-0E65-43D6-AE83-61BF50BB75F1 by [url=https://www.flickr.com/photos/140393666@N08/[/url], on Flickr
AC21BB64-61BA-47FA-B0E5-1B8672AAD1EC by , on Flickr
I carpeted the area as suggested in this thread and have noticed zero noise from things moving around. I fit a power inverter, air compressor with hose, Gerber hatchet, 30' recovery strap, small first aid kit and a bivy sack so far.
