First off, I paid $6900 for a 2000 4 runner 4wd, v6. Engine and interior in perfect condition.... so what's the catch?
Well, the underneath is rusted. Badly. Can't change the fuel filter b/c the nuts/bolts are rusted that looks like a weld. Will need a workaround for that later...
biggest question is rear axle, differential housing. i don't hear any weird noises or anything, and everything works perfectly. I would like to change all the fluids and do typical maintenance on it. The bolt on the rear diff is rusted and i have not even attempted removal. Flakes of rust (a few millimeters thick) you can actually pull off the rear diff. it's in bad shape. Here are some pics, but most of the rust i've pulled off (seriously).
I am thinking of just replacing the rear axle completely. I think i am using the wrong terminology, so whatever i'm search for is not pulling up. Is this not the rear differential? How do I go about getting a new one or at least a new housing? Should I replace the rear axle as well?
UPDATE! Success in removing stuck bolt! I bought the Irwin Bolt removal toolkit off amazon.com (in 24mm) and used a large breaker bar to get it off. My buddies electric impact wrench wouldn't budge it. Fluid was pretty bad, but not many shavings on magnetic bolt. Here are some pics:
New Fuel Filter i installed:
transfer case: already changed this fluid. bolts came out easy, and it was relatively clean.
Diff bolt out, tools used: breaker bar, 24mm bolt-out socket, aero kroil penetrating oil
New bolt, messy driveway! I had a bit of a hard time getting the magnetic bolt out on the bottom, but damn when i gave (i used the impact wrench) i was not prepared for the bolt to come completely out.
