08-13-2009, 10:27 PM
Tire Size Question(yes i've searched and seen the million other threads w/ same name)
So I know 265/75s can fit if your riding the taller coils or for the most part a 4WD model. Having an '01 2WD though I would say i have the shortest coils of any 3rd gen(probably). The 4runner sits slightly taller in the rear and even though it looks room enough for the upsize the front looks like it would rub.
With that out of the way I was looking at tires in Walmart and saw these Goodyears. They Have them in a 265/75, but no 70. The next smallest size was a 245/75. Would that size be smaller than my current 265/70s? Or with its more aggressive tread and sidewall would it look about the same size?
01' Toyota 4Runner Limited
The 4Runner
BrushGuard, Flowmaster, Rims, Rack, Clear Corners, Black Bumper Lights, Black Emblems/Shaved, Kicker Subs
08-13-2009, 10:56 PM
Ok, for one they don't make 260/75/16 and 245/75/16 are actually 30.5" tires but are more narrower than the stock 265/70/16. My advice would be to find a different set of springs before changing tires sizes. I ran 265/75/16 for awhile with my stock 98 sprigs with no issues. Still have them sitting in my basement if your interested.
98 4Runner Limited,265/75/16 Hankook Dynapros, KMC XD Black Hoss Wheels, Hella 500, Tokico, PP 1" Springs, Optima Red 34R, K&N, JL, Kenwood
08-14-2009, 12:23 AM
What tires are you looking at from wal-mart? Are you opposed to doing a little trimming. You really shouldn't have a problem overall with a 265/75 but you may need to trim on the inside of the fender flares. If I remember correctly your 4Runner doesn't see much offroad time? I wouldn't sweat it. I have never heard of anyone with any year 4Runner just plain not being able to fit them. I would shy away from the 245s but I just can't fathom going down in tire size... its just not my style. Good luck with whatever you choose and hopefully someone can chime in with a 01-02 with some first-hand experience.
1998 Toyota 4Runner Limited
1A5 V6 3.4l 4x4 w/ RR DIFF LOCK
Exterior: TRD Tacoma wheels painted black, Spidertrax spacers, 20% Tint, Coleman Safari Rack, clear corner lenses, custom dents
Interior: Alpine CDA-9883, Polk MOMO 6.5", Infinity Reference 5.25", Memphis 16-STT150 2 channel amp, custom mud
Offroad: OME 3" lift (881/890), 1" diff. drop from Toytec, Tacoma whip antenna, extended rear diff breather, gray wire mod, 285/75/16 BFG KM2s
08-14-2009, 11:48 AM
Originally Posted by bgmac
Ok, for one they don't make 260/75/16.
meant 265,*edited it above*
don't remeber exact name, they were goodyears similar looking to the duratracs. and yea trimming is out of the picture. and yea off-road wise it is pretty much just straight driving thru mud so the kind of full turn needed like ive seen with peoples rock crawling photos aren't needed.
anyone think this would be a good idea? or would the inch make the front alot higher than level?
http://www.4wheelparts.com/Lift-Kits...n=DAYKT09105BK
The 4Runner
08-14-2009, 12:31 PM
yeah unless your tires are bald right now spend the $250 bucks for a coil and spacer lift then get some real tires, you'll be alot happier in the long run, rather than waiting another few years for the new tires to wear out and do it then.
08-14-2009, 01:51 PM
I've seen the tires you are talking about Sloan. They look decent and are priced really well.
Just get the 75's.
Check out my garage.
08-14-2009, 03:51 PM
You messed up the tire size again, 265, not 256! Try another edit.
265/75's usually fit anything with little to no problems. The gap between the top of the tire and wheel arch is not the area you should be concerned with. It's the gap between the tire and the front mud flaps when the steering is turned that causes issues but can be easily trimmed if needed. At full left or right lock, inspect the tire-mudflap gap and you'll be able to estimate if the increase in tire diameter is going to make contact. Don't forget that the gap closes up a little under suspension compression.
08-14-2009, 10:44 PM
edited! , i put my area code that time in instead lol.
yea clemson they were only 165 so I though that was a good deal. if i post some pictures tomorrow with close ups you guys think you can give me some better help?
The 4Runner
08-15-2009, 01:33 PM
ok here are some pictures today and i took some measurements, not sure if they will help though? the front from ground to the middle of the fender flare is about 33 inches. the rear comes in about an inch higher at 34.
Front:
Back:
Overall:
this is how i measured, hope it was right (rear tire)
The 4Runner
08-16-2009, 11:54 PM
bump for help? and did some googeling and fount the tires on a '02 2WD 4runner. The tires are Goodyear Wrangler Authority.
The 4Runner
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
