After looking at my 97 It appears that there is a phillips head screw holding the reservoir. Unscrew that, unplug the level indicator, and lift up with a slight rocking. Usually the seals are quiet tight, so it will take some pulling. I remember replacing mine a few years back. I believe it is still the same though. Its also nice if you can remove the fluid before attempting.
Can't beat the Cental Coast!
'97 SR5 v6 4x4 Desert Dune
Tundra Brakes, Sliders
