Old 08-18-2009, 06:26 PM #1
tomtundra's Avatar
tomtundra tomtundra is offline
Real Name: Tom...but don't tell.
tomtundra is on a distinguished road
tomtundra's Avatar
Ultimate Build?
Been a spectator for a while, now I feel I'm ready for my first post. I own a 98 4Runner, V6, 4X, SR5, A/T, with 140k miles, and I am planning my build. I'm want a daily driver with some wheeling capabilities and additional attitude under the hood; the vehicle is currently stock and does runs well.
This is where the group comes in, focusing on engine and suspension performance - What should I have on my list, excluding the Supercharger for now (don't want to pay for premium gas on a daily driver), what would you guys do? I've got a pretty good size budget for this build, so don't hold back.
Looking forward to you comments.
tomtundra is offline   Reply With QuoteReply With Quote
Old 08-18-2009, 06:31 PM #2
haddix's Avatar
haddix haddix is offline
haddix is on a distinguished road
haddix's Avatar
Arb bumper with warn winch, stubbs or similar sliders, coilovers up front(your choice brand) land cruiser coils in the rear with bilstein 5125 shocks, custom rear bumper with tire carrier. 1 or 2' body lift so you can fit 35's go with am ud tire(cooper stt or mtz), Reagear to 4.56 or 4.88 and add lockers.
2007 FJ Cruiser
haddix is offline   Reply With QuoteReply With Quote
Old 08-18-2009, 06:32 PM #3
haddix's Avatar
haddix's Avatar
For under the hood you can add a cold air intake and do an exhaust. Thats about all you can do there without adding the s/c and fuel upgrades..
2007 FJ Cruiser
Old 08-18-2009, 09:15 PM #4
Pikeman's Avatar
Pikeman Pikeman is offline
Pikeman is on a distinguished road
Pikeman's Avatar
I agree with Haddix. Sonoran Steel and Toytec Lifts are both good sources for various lifts. Look at my sig for my build. I use mine as a daily driver and it is great and very capable off-road. Would regear and add locker.
Performancve wise, deckplate mod or Cold Air intake. Headers and Cat back exhaust. If you have another vehicle you can send your ECU to Jet Performance and have it reflashed (similar to a chip or power programmer). they will send it back to you with new programming. If you choose to do it I would wait until you have the other mods done so they can prgoram for those also.
99 SR5 V6 4WD- just started
SOLD1998 T4R SR5 All-Pro CO's, UCA's and Sliders, SS 1.2 rear only DIY rear bumper, Aussie Locker and 1st gen roll bar mod. Outdoor Logic Front bumper, roof rack and Vision X lights.
Pikeman is offline   Reply With QuoteReply With Quote
Old 08-18-2009, 09:23 PM #5
FoneRunner's Avatar
FoneRunner FoneRunner is offline
FoneRunner is on a distinguished road
FoneRunner's Avatar
If you do regear, hang on to the third member and front diff....cause if you don't live in Colorado, they are apparently really hard to find and cost a lot of moola. I can't wait to see the posts on your progress...I'd like to boost performance on my 98 too...
'98 4Runner Limited Desert Dune 4WD lifted, locked, TJM'd, OME'd, LC'd, LED'd, ACC'd, CB'd, Gobi, Hilux'd, JDM'd, etc...
'98 Tacoma SR5 slightly built, '15 4Runner TEP
FoneRunner is offline   Reply With QuoteReply With Quote
Old 08-19-2009, 01:07 AM #6
tomtundra's Avatar
tomtundra's Avatar
Haddix, thanks for the suggestions - especially the ECU Flashing, I wasn't thinking of that. I'll be sure to keep you and the rest of the group posted on my progress.
Old 08-19-2009, 01:11 AM #7
tomtundra's Avatar
tomtundra's Avatar
Sorry Pikeman, gave credit to Haddix on the ECU suggestion - thank you as well. I see you're in SoCal, so am I - maybe I'll see you at SoCal gathering of T4R.ORG.
Old 08-19-2009, 03:28 PM #8
haddix's Avatar
haddix's Avatar
When are you starting this build?
2007 FJ Cruiser
Old 08-19-2009, 03:59 PM #9
theizzardking's Avatar
theizzardking theizzardking is offline
theizzardking will become famous soon enough
for the lift,
http://www.sonoransteel.com/store_co..._liftkits.html
kit includes
System 1.2: The "All Toyota Factory Coil" lift: Adjustable 1.5" to 2.5" Front & 3.5" Rear. The kit with the best "pure off-road" prowess bar none. 4WD Only.
* Ideally this lift is for a truck with custom front & rear bumper as well as rock sliders. If your truck has a stock front bumper, that is fine, but if you have a stock rear bumper a Class III trailer hitch installed with the complete stock rear bumper/spare tire along with a set of functional rock sliders would be acceptable. The rear coils are brand new, the are made of a small diameter wire with wide wraps. They will require some time to settle to the final height. All of the data for this lift kit was compiled with springs that had between 40K and 100K miles on them. These coils will hold out for an extremely long time, but are a tad tall when brand new, plan on some settling after install. This is not the case with the front coils, those consist of a large diameter wire with tight wraps, they will not change after install. *
Front:
Toyota Progressive TRD Front Coil: Driver/Left Side (ONE)
Toyota Progressive TRD Front Coil: Passenger/Right Side (ONE)
Toyota Stover Nuts (TWO)
Toyota Upper Shock Bushing (TWO)
Sonoran Steel Fabrication L.L.C. Custom Polyurethane Top Plate Retainers (TWO)
Bilstein 5125 Series Nickel Plated Adjustable Heavy Duty Front Shocks (TWO)
Sonoran Steel Fabrication L.L.C. Front Differential Drop Spacers (TWO)
Rear:
Toyota FZJ-80 Land Cruiser Coils (TWO)
Bilstein 5125 Series Nickel Plated Shocks (TWO)
Sonoran Steel Fabrication L.L.C. Custom Polyurethane Shock Bushings (TWO)
Sonoran Steel Fabrication L.L.C. Adjustable Trac/PanHard Bar (ONE)
Sonoran Steel Fabrication L.L.C. Extended bump stop Adapters with Daystar Competition Style bump stops (TWO)
Sonoran Steel Fabrication L.L.C. Rear sway bar adjustment brackets (TWO)
Sonoran Steel Fabrication L.L.C. Braided Stainless Steel extended brake line or lines (1996-2000 one line, 2001-2002 two lines)
Sonoran Steel Fabrication L.L.C. Parking/Emergency Brake bracket (1996-2000 Only)
1996 to 2000 Toyota 4Runner 3.4 Motor: 1.5 to 2.5" Front & 3.5" Rear Lift: $1239.00
1996 to 2000 Toyota 4Runner 2.7 Motor: 1.5 to 2.5" Front & 3.5" Rear Lift: $1239.00
2001 to 2002 Toyota 4Runner 3.4 Motor: 1.5 to 2.5" Front & 3.5" Rear Lift: $1274.00
1996 to 2000 Toyota 4Runner 3.4 Motor: REAR ONLY: $692.00 (Does not include any lift parts for the front)
1996 to 2000 Toyota 4Runner 2.7 Motor: REAR ONLY: $692.00 (Does not include any lift parts for the front)
for body armor go with bud built
http://www.budbuilt.com/new/96-02%204Runner.html
and shrockworks for the bumpers and sliders
http://www.shrockworks.com/Toyota-4R...-pr-16217.html
under the hood do
deck plate mod,isr mod, intake up grade, tb spacer, jet chip (you can program them with odbII now no need to send off for flash)
headers
exhaust
regearing will also help out alot, if your auto and running 32's or 33's run 4.88's if your stick you can rock the 4.56's better.
theizzardking is offline   Reply With QuoteReply With Quote
