I was bored and wanted to replace all the dome bulbs with LED bulbs so I went up to Advanced Auto Parts and looked for bulbs but no luck. So then I found a pair of LED "driving lights" that were supposed to mount to the bumper and are only for "off-road use or show." I tested them and they weren't really that bright so I knew they would be perfect for the cargo area. It came with all the wiring and instructions and a switch. I had to buy more wire because I was putting them in the cargo area rather than up in the front near the engine and battery.
So I marked up some spots for the holes to mount the lights and then a hole for the wires to go into. I also dremeled out a little spot for the light switch to go into. Had to use a glue gun to get it to stay because super glue and Goop didn't work. I attached the power cable directly to the battery so the lights can run without the car on. Might be adding another fluorescent type light or LED to the top of the cargo area later.
The switch and the drivers side light
Closeup of the LED light
Passenger side LED light
Lights on with the dome light off
One of the lights on
