09-11-2009, 08:44 AM
Guest
Guest
Before the lift...
Rig is being picked up in an hour by the local 4x4 shop, here are 2 pics of it before the new suspension lift and NTG tires...
09-11-2009, 03:41 PM
Guest
Guest
Just stopped by the shop, truck up on lift, new tires are mounted, shocks struts and coils about to go on...shop found a broken drivers side sway bar end unit, nice catch, thats a quick $100 in parts but would prob explain all the damn veering i've been feeling lately. Anyone have experience working with any of the products which remove surface rust chemically and clean the undercarriage real well? This shop is also able to build a swing out spare tire carrier and any bumper work i'd like done. bunch of young guys, motor heads that know their stuff.
09-11-2009, 03:52 PM
sounds like you should just give them a blank check and let em go crazy on the 4runner! lift, bumpers, armor, spare tire carrier, hell yeah!
2000 Limited 4x4 w/ e-locker. ToyTec 3 inch lift adjustable coilovers up front, OME 891's in back, diff drop, Badlands front bumper with XRC8 winch, homemade sliders, addicted offroad rear bumper, Lil' Skips belly and gas tank skids, spidertrax wheel spacers, 285/75 BFG ATs, Cobra CB, Kenwood DDX 712, MagnaFlow exhaust, rear diff breather mod, blue/red wire locker mod, B&M xmsn Supercooler
09-11-2009, 04:08 PM
Guest
Guest
tempting, tempting!!!
09-11-2009, 04:46 PM
i have alot of experience with fighting rust when restoring my old vw's ,
there is no such thing as a chemical rust killer, it merely encapsulates it and converts it, anything short of getting a wire wheel out and doing it right may still have issues in the future and require upkeep, depends on your needs how much rust and all of that, here is a shoot out a guy did of various rust products
http://www.thesamba.com/vw/forum/viewtopic.php?t=131753
other products people use
http://www.halonmarketing.com/mall/R...tal%20Prep.php
http://www.eastwood.com/eastwood-rust-converter.html
http://www.rustcheck.com/howworksasp.asp
personally i'd just clean it up right with a wire brush or softer grinder and then spray with some por-15 then rhino line to go the extra distance, you should post some pics so we can see how bad this is.
09-11-2009, 05:05 PM
Guest
Guest
i figured the wire brush was going to be my best bet. the rust is very minor, not anywhere close to being a problem. just thinking of things to do that dont cost money.
09-11-2009, 05:56 PM
I also agree with the wire brush. The other day when I was under my truck I discovered a broken end link on my front sway bar and that the bushings were toast and one was completely gone. Time for the poly bushings with the grease fitting mounts someone mentioned in another thread. Cant wait to see the pics in a few hours when it is done.
99 SR5 V6 4WD- just started
SOLD1998 T4R SR5 All-Pro CO's, UCA's and Sliders, SS 1.2 rear only DIY rear bumper, Aussie Locker and 1st gen roll bar mod. Outdoor Logic Front bumper, roof rack and Vision X lights.
09-11-2009, 06:23 PM
Guest
Guest
Can you tell me what the poly bushings will do versus the stock ones? truck should be back in a couple hrs...i cant wait either!
09-11-2009, 06:40 PM
Poly bushings are stiffer and longer wearing then the soft rubber ones. I know in the other thread they were mentioned in that you could get the sway bar bushing with new clamps that had grease fittings. This is good because it helps them last and keeps them from squeeking.
09-11-2009, 07:59 PM
Guest
Guest
The lift is done, shop says truck drives amazing. They are on their way back from picking up the only tie rod in the city that will fit my rig as it broke during alignment. They are taking care of the charge for that piece, nice of them. Another hour or so...
09-11-2009, 09:44 PM
Guest
Guest
Rig is now back in my garage. I apologize for not posting pics yet, but its dark out and my outdoor lighting isnt sufficient. IT LOOKS AMAZING. The 881s/906s caused the truck to have a LEVEL stance now which looks incredible, and the NTG tires 265/75/16 are the perfect size. Could have done 285s, but for what I wanted, the need to switch wheels would probably have been there and I like the stock rims too much. Next post will be a thread with pics.
09-11-2009, 09:50 PM
No pics...WTF.......Im just busting your balls man. Im glad it turned out good. How is the ride?
98 4Runner Limited,265/75/16 Hankook Dynapros, KMC XD Black Hoss Wheels, Hella 500, Tokico, PP 1" Springs, Optima Red 34R, K&N, JL, Kenwood
09-11-2009, 09:55 PM
Guest
Guest
i only got to drive it about 5 feet, from the driveway into the garage (i now clear it by about 4 inches). The shop mgr brought it back home for me as it was a little late to take the infant out. But he said he beat the hell out of it and it drives ridiculously well.
09-13-2009, 12:37 AM
Originally Posted by theizzardking
sandblast then waxoyl
