09-12-2009, 11:10 PM
4runner dies at stop sign ? ?
hey guys, riding home tonight in heavy rain for about 30 miles and when i get close to my house, i pull up to a stop sign and my 4runner just dies. i cranked it right up and just drove it on home. what could have caused this to happen. 99 4runner, 125k
09-12-2009, 11:35 PM
Was it just a one time occurance? Have you driven it since?
09-12-2009, 11:52 PM
Banned
Banned
3RZ or 5VZ?
Fuel filter comes to mind.......any other issues?
09-13-2009, 12:13 AM
yea, it just happened that one time, i cranked it up and it ran fine. but i was only a half mile from home. 3.4 v6
Reason: left info out
09-13-2009, 04:07 AM
Could be that your throttle body got stuck closed for a second, happend on my Fiance's 01 Camry. If it happens again what I did is remove the air intake hose, spray some carb cleaner on it and move it around a little.
09-13-2009, 08:31 AM
I had mine stall once a few months back..I was sitting in a parking stall at the store with the a/c cranked for about 10-15 mins. Went to back up and it just stalled. Started it back up and has never happened again. So, I dunno..take this for whatever it worth.
98 4Runner Limited,265/75/16 Hankook Dynapros, KMC XD Black Hoss Wheels, Hella 500, Tokico, PP 1" Springs, Optima Red 34R, K&N, JL, Kenwood
09-13-2009, 12:40 PM
wife just called me and said it had died on her going down the road. i know about the fuel gauge issues with the 4runners, my fuel gauge says i have about 1/8 of a tank, my fuel light hasnt come on yet, so i suppose there is at least 3 or 4 gallons in there.....whats going on here?
09-13-2009, 01:23 PM
well, there is afew different things it could be. TPS sensor (throtle position sensor) or IAC sensor (idle air control) Dirty maf sensor http://www.top4runners.com/ja/cleanmaf.html or your fuel filter is clogged. Im betting its one of these sensors. I had this happen a few years back in one of my jeeps and it was the IAC sensor..it would just stall for no apparent reason.
09-13-2009, 06:30 PM
Real Name: Bryan
Real Name: Bryan
I'd bet on a dirty IAC
Millennium Silver 2001 4Runner SportR5lander
Photo Timeline - Solid Axle Club
All-Pro, Fox, Eibach, OME, Goodyear, Trail Gear, Yukon, Solo Fabworks, Marlin, TJM, Smittybilt, Front Range Offroad, Inchworm, Addco, Savage Offroad, B&M, Borla, Pioneer, Cobra
Northeast 4Runner Owners Association
09-14-2009, 01:35 AM
If it repeats in heavy rain, you should think about intake leak. I had this happen on a car fresh from the mechanic because he forgot to tighten the clamp from the airbox to the carb. Water in the intake is a good way to kill an engine (kill as in stop, not ruin--at least in small quantities.)
You can let things dry out and take a spray bottle and mist the air intake system from filter box on in with the engine running. If the motor coughs, there's your problem. If it doesn't, there are lot's of other suggestions.
My Backyard Frame Swap
09-14-2009, 11:10 PM
I had a similar problem turns out it was a bad mass air flow sensor. yours may need to be cleaned or replaced if it turns out to be the source of the problem. I brought mine into the dealership and they hooked it up to get diagnosed readings were all over the place.
2000 4Runner SR5 V6 4X4 auto
TRD ceramic coated headers, DRL lights turned off !!, Royal purple fluids, Toyota Tranny cooler,silver star headlights, PIAA HID corner lights, Hella fog lights, LED Tail lights, PP1 springs Bilstein shocks, Addco sway bars F/R, EBC Rotors & Pads, Gloss black calipers, Russell SS brake lines, urethane steering bushings, Nitto Terra Grapplers on Black Rock Viper wheels, Air elbow mod, Deck plate mod, Rear diff breather mod, Inline weather guards****** Friend don't let friends drive stock ******
