Old 10-07-2009, 10:45 PM #1
greyrock greyrock is offline
greyrock is on a distinguished road
Requesting tips for finding clock problem
The digital clock in my '98 T4R has been working intermittently for a couple years now, ever since the dealer did a dash replacement after a break-in.
Judging from the fact that its functionality appears to depend on the weather/temperature/humidity/etc, and I can occassionally get it to work by gently pounding on the top of the dashboard, I'm guessing it's a loose connection some place.
So my questions are:
  1. How can I access the back of the clock? If that involves taking off the whole dashboard, I think that's beyond my skill level. But if there is a straightforward way to get to it, I'll give it a shot
  2. Obviously there is a connection at the back of the clock itself. Where would the other end of the connection (i.e. the power source) be, and how straightforward is it to get to that?
Thanks in advance for any suggestions.
greyrock is offline   Reply With QuoteReply With Quote
Old 10-07-2009, 10:56 PM #2
spinn spinn is offline
spinn is on a distinguished road
It's fairly easy to pull out the dash (requires removing center console to access front panel). The clock problem is the same issue (very common) that I have. I found this site and plan on sending it to him to fix...as $200+ to the dealer is not goin' to happen.
http://www.subaru-clock.com/
spinn is offline   Reply With QuoteReply With Quote
Old 10-08-2009, 01:30 AM #3
quicksilvr's Avatar
quicksilvr quicksilvr is offline
quicksilvr is on a distinguished road
quicksilvr's Avatar
The problem is internal inside the clock. Pounding on the dash was an indirect way of vibrating the clock unit. If you just tap the face of the clock with a pen, it works much better. You won't be able to fix the clock yourself unless you do that sort of thing with eletronics for a living. I'd send it to subaru-clock like mentioned above.
2001 SR5~Thundercloud Metallic~3.4L Auto~4x4~260k miles~TRD 2gen black Supercharger~URD AFR Calibrator~B&M 70264~Bilstein Adjustable w/ tall '99 fronts~ProComp 3" rear springs~Nitto Ridge Grappler 285/70R17's on 17x9 Enduro's~Yakima RailRider w/48" bars~ScanGauge II
quicksilvr is offline   Reply With QuoteReply With Quote
Old 10-08-2009, 03:34 AM #4
ChildrenOfBodom's Avatar
ChildrenOfBodom ChildrenOfBodom is offline
Moderator
Real Name: James
ChildrenOfBodom is a glorious beacon of light ChildrenOfBodom is a glorious beacon of light ChildrenOfBodom is a glorious beacon of light ChildrenOfBodom is a glorious beacon of light ChildrenOfBodom is a glorious beacon of light
Moderator
Real Name: James
gettin the clock out is very easy.
pull up the e brake, pull the whole cupholder bit up and it comes out.
pull the shifter bezel up, it's out.
then pull the whole center piece out towards you.
it's all snap in clips. the clock is held in with clips.
I would replace the clock, it's common for them to die out. mine used to be intermittent.
I got one out of a traded in 4Runner at my dealership. it was from a 97 with 260k.. yet still the clock worked great.
still does.
IG: @jimharb | YouTube | '99 Limited 2WD |
'99 4Runner - 2.7L 3RZ-FE - TRD S/C - 4WD Conversion + R150F 5-Speed Swap - Imperial Jade Mica on Oak
'87 4Runner Turbo - 2.4L 22R-TE - CT-26 Supra Turbo - W56 5-Speed Swap - Red on Red
'90 4Runner 2-Door - 3.0L 3VZ-E - Auto to R150F 5-Speed Swap - Red on Gray
'94 Supra Turbo Targa - 3.0L 2JZ-GTE - Marlin Crawler R154 - Imperial Jade Mica on Black
'89 Supra Turbo Targa - 3.0L 7M-GTE - Marlin Crawler R154 - White Package on Blue
'89 Pickup DLX 2WD - 2.4L 22R-E - W55 5-Speed - White on Blue
ChildrenOfBodom is offline   Reply With QuoteReply With Quote
Old 10-08-2009, 03:38 AM #5
Elton H's Avatar
Elton H Elton H is offline
Elton H is on a distinguished road
Elton H's Avatar
mines been broke for awhile i just use the one on my pioneer deck
98 4runner sr5 3.4L 5spd 4x4 e-locker sold 10/2/11
07 tundra 5.7L 4x4 limited dc was my moms r.i.p 3/19/11
Oregon Toyota Owners Club
Elton H is offline   Reply With QuoteReply With Quote
Old 11-06-2009, 11:45 PM #6
Wow, thanks for the tips.
I'm going to give it a try, and if I can get it out, I'll send it to subaru-clock as suggested.
Thanks again!
still does.
Old 11-07-2009, 12:45 PM #7
Ron Helmuth's Avatar
Ron Helmuth Ron Helmuth is offline
Real Name: Uhhh this is my real name
Ron Helmuth is on a distinguished road
find a part out
find a 3rd gen part out near you....get to know your local junkyards
still they will want too much for it- being just a clock and all.
The bezel comes free but the trim surrounds need at least loosened. There are 2 screws on side of center console trim to remove. Find a thread regarding radio replacement for pics.
I like Ritzy's writeups and pics myself....some folks have found other items to mount in there instead to fill the hole and just eliminate the clock.
06 4th gen V8 4WD of course...
08 Honda Ridgeline RT
05 Scion xB-the toaster-daily driver
my Yota Fanatic photos are on Facebook- here is link:
http://www.facebook.com/album.php?ai...5&l=5795132731
Ron Helmuth is offline   Reply With QuoteReply With Quote
clock , intermittently , t4r , working
