Originally Posted by C C
Ok yes this is what I was wanting to verify. I understand the valve body design mattering depending on year, however is it safe to say that any 99-00 used transmission would fit my truck? It is indeed a 4WD with the push button Multi-Mode & e-locker.
You can use any V6 (4-cylinder has a different bellhousing/etc.) trans from '96-'00. If you use a 96-98 trans, you need to swap the neutral safety switch on the side of the trans. You will have to swap over your transfer case if you get anything but a 99-00 Limited trans.
Differences in the valve body are internal (passage/pipe locations, etc.) and don't affect the control of the trans. As I said earlier, I have a '97 trans in my '99. Others have gone the other direction.
'99 4Runner SR5 Auto -
4WD swapped
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
