Old 11-06-2009, 06:41 PM #1
brad7410's Avatar
brad7410 brad7410 is offline
brad7410 is on a distinguished road
brad7410's Avatar
96 rear axle seals
So here's the deal. The rear outer axle seals were leaking onto my rear brakes pretty much making them useless. Had to get a garage to fix because I had dads car in my garage. Funny how that works out. Dad gets his fixed for free and I have to pay for mine. Anyways I had the seals replaced but they were telling me that the outer seals (as in the seal in hub?????) were leaking also and there was a special tool to remove the ABS wheel to get it all apart. We tried just replacing the axle seals to see if that worked. So the end of last week (one week after getting it back) the new front rotors were warped so it went back for warranty and they told me that the axles are still leaking so the seals in the hubs need replacing. I'm a front wheel drive GM guy so my knowledge is limited on this. Every rear end I've worked on has cir-clips that have to be removed to remove the axle and there is only one seal. This doesn't really make sense to me. Anyone have that issue before? or is a total croc of shit? Sorry, it just seems fishy to me.
Brad
brad7410 is offline   Reply With QuoteReply With Quote
Old 11-06-2009, 11:28 PM #2
SkidPalace's Avatar
SkidPalace SkidPalace is offline
SkidPalace is on a distinguished road
SkidPalace's Avatar
Brad, a little research in to the subject would have given you all you need ofr your axle seal issue.
There are inner and outer seals on our rear axles. The inner is a relatively easy driveway fix, the outer is a machine shop job unless you got a press in your garage. Replacing the outer seal requires replacing the axle bearing and ABS sensor.
This problem is VERY common in our generation trucks.
A repeat axle seal failure is most definitely a differential breather valve clog.
2015 Magnetic Grey Limited with Redwood interior. 275/55r20 Michelin Defender LTX on stock wheels. Daystar 2.5/1.5 puck lift.
Gone but not forgotten: Black 2000 SR5 "Highlander", Supercharged, Black pearl emblems, Factory e-Locker.
SkidPalace is offline   Reply With QuoteReply With Quote
Old 11-07-2009, 12:50 PM #3
Ron Helmuth's Avatar
Ron Helmuth Ron Helmuth is offline
Real Name: Uhhh this is my real name
Ron Helmuth is on a distinguished road
use correct axle seal to be sure
yes there are inner and outer seals
Be sure the inner seal part number used ends with digit #6 and use the Toyota suggested replacement.
repeated failure can be many reasons-it's oversimplifying to say it has to be a clogged breather. None the less that is cheap insurance to replace it and might as well extend it upwards while at it if you ever cross water.
I had my drivers side rear axle seal done at 44K and again at 99K. The first time the incorrect part number was used. Toyota has updated the recommended seal and redesigned it.
Again be sure the actual inner seal part ends with digit #6.
06 4th gen V8 4WD of course...
08 Honda Ridgeline RT
05 Scion xB-the toaster-daily driver
my Yota Fanatic photos are on Facebook- here is link:
http://www.facebook.com/album.php?ai...5&l=5795132731
Ron Helmuth is offline   Reply With QuoteReply With Quote
Old 11-07-2009, 02:47 PM #4
fightman80's Avatar
fightman80 fightman80 is offline
fightman80 will become famous soon enough fightman80 will become famous soon enough
fightman80's Avatar
Smile
Originally Posted by skidpalace View Post
brad, a little research in to the subject would have given you all you need ofr your axle seal issue.
There are inner and outer seals on our rear axles. The inner is a relatively easy driveway fix, the outer is a machine shop job unless you got a press in your garage. Replacing the outer seal requires replacing the axle bearing and abs sensor.
This problem is very common in our generation trucks.
2x on the diff breather clog!
fightman80 is offline   Reply With QuoteReply With Quote
