01-03-2010, 11:40 PM
LED lights: Turn Signals and Corners
Hey guys, I just ordered some clear corners and bumpers this weekend and cannot wait to get them in the mail.
I would like to get some LED lights for the bumper and corners.
First, should I get these for the turn signals: 2 AMBER 7W HIGH POWER 20 LED PARKING/TURN SIGNAL BULBS 7443 7440
Or should I get these: V-LEDS AMBER 20 LED HIGH POWER TURN SIGNAL BULBS 7443-SACK?
Also, WHITE or AMBER colored LEDs for the corners? Opinions?
Thanks
Silver 2000 4WD 4runner Limited***Audio: Pioneer FH-P8000BT Head Unit, MTX Terminator Series 12" Subs***Misc: Yakima Roof Rack, 15% on passenger and driver side to match the back with 35% on windshield***Lighting: 6000k 55W HIDs....
01-04-2010, 12:20 AM
ive had a pile of diff led bulbs there not very bright
98 4runner sr5 3.4L 5spd 4x4 e-locker sold 10/2/11
07 tundra 5.7L 4x4 limited dc was my moms r.i.p 3/19/11
Oregon Toyota Owners Club
01-04-2010, 12:33 AM
i made my own corner led's for like 15 dollars
01-04-2010, 04:35 AM
I purchased a set of LEDS from V-LEDS for my clear corners but was disappointed because it looks tacky when my HID lights are on and the aren't matched
2001 T4R SR5 4WD
01-04-2010, 05:11 PM
Well what would kind of bulb do you guys think should go in my clear corners?
I'm waiting to get my 8000k hid kit right now, and I'm sure I will not be able to make the clear corner lights match up very well with the headlights.
mistaj0hnny, it looks like your clear corners are turned off completely with the headlights on. Did you just give up on the clear corner bulb idea?
I wanted to put some kind of bulb in the clear corners but have no idea what I should put in there.
I need some more suggestions on what to do... What have other people done?
01-04-2010, 06:42 PM
What color do you have bootown? Do you think white LEDs would look good with 8000k headlights?
01-04-2010, 07:05 PM
Real Name: Taylor
Real Name: Taylor
amber leds from v-leds
not hid's mind you
but as far as turn signals its going to be much more tricky, but i built up a kit for the front and rear turn signals, plus the appropriate electronic flasher unit.
http://www.toyota-4runner.org/classi...tml#post491255
01-04-2010, 07:13 PM
Super Moderator
Super Moderator
Just trying to help make the mod go smoothly....
What are you going to do about the blinker? The reduced load of the LED will cause it to flash really fast as if a bulb was burned out. In general you can add resistors or change the flashers (turn signal and 4-way). More here: Blinker/Warning Fix
Edit: Looks like SilverBullet01 and I were typing at the same time
Chris
07 Salsa SR5, 4wd Cyclone pre-cleaner , Aux Transmission Cooler, Hidden Hitch 70779 (600/6000lbs, WDH=730/7300lbs), AirLift 1000, FJCruiser front springs (& now rear too!), Axle Vent Mod, Swaybar Bushing Upgrade, V6 Tick Reduction, VSC off mod, Maplight Mod, 255/75/17 Goodyear Wrangler SAs, Tailpipe Mod
01-04-2010, 07:14 PM
Real Name: Taylor
Real Name: Taylor
v-leds doesnt carry an iso flasher unit, they have a jso, but it needs to be rewired like i did in the previous post
edit: indeed sir
01-04-2010, 07:25 PM
Super Moderator
Super Moderator
edit: indeed sir
Awesome... I know about this issue due to non-3rd gen experience. I just didn't want Rob to get the new lights and have not work.
I just read those posts. The flasher with jump wires look easy enough. Great info. Thanks
Poor Zandro! The roof collapsing on that sweet diesel Runner.
Chris
01-04-2010, 08:00 PM
stick with amber that way u can make them into turn signals also
01-04-2010, 10:30 PM
Alright well it is looking like I should go amber then for the corners. And the LED blinkers sound like a small project.... Thanks so much for all your help guys
02-03-2010, 01:23 PM
Hey, so im new to the site..I have a 02. Where can I find some clear corners.. The sites I've seen don't have the right ones...Any suggestions?
02-03-2010, 01:24 PM
