Originally Posted by ryani
Thanks guys for the info. What kind of anti freeze are you guys using when you do the flush?
It doesnt matter what kind you use, as long as you don't mix different types (ethylene and propylene glycol) of coolant. Personally, I use the green stuff (Prestone), but I perform a complete flush every year on my vehicles. I will drain the AF out, then fill with DI water, run it then drain it again. Repeat the process until the water is clear. Then I fill with the new coolant. This process will ensure that your coolant is completely removed from the block (which is not done with a simple drain and fill).
