Originally Posted by bak3rme
yep he was right, the 2nd set of numbers is the ratio to the first set..in which my case i have 275/70..which turns out to be 192.5 mm...whereas recommended size is 265/70 which is 185.5 mm ..so i really have a 7mm lift! WOOT!
Yup, exactly why 265/70/17 is a 31.6 inch tire while 285/70/17 is a 33 inch.
I heard somewhere that the second number is a percentage of the first number... so the height of those two differs as 70% of 285 is a larger number than 70% of 265.
So likewise 235/75 vs 225/75 would account for just a tad bit more height.
I hope this thing doesn't have a ridiculous amount of miles then what I paid for.
Don't worry about your miles, if anything it's really not off by really much at all. It's such a small difference. Just imagine 11.7% off like mine, or some of the people with 35's and 33's.
If it really bugs you, you can look into Dakota Digitals speedometer correction box, which I will install soon. A member here, 240m3srt, has done this to account for his 35" tires.
And hey, like John said, looks like you have less miles!
