This is an old thread, but it's still useful some 12 years later. I thought I'd update on the pricing I'm seeing these days as I am going through the same decisions.
2000 4x4 3.4 Limited, 280K
For a used or remanned install, it looks like the labor has not gone up much in the past 12 years. Shops around me are still quoting around $600 labor, plus tax, and sometimes plus ATF and parts.
Cost of rebuilding the trans seems to vary
significantly based on shop. Cheapest I found for a rebuild + labor was around $2,600, plus tax. Highest I found was $4,000 (yes, for a
rebuild, not remanned). Longest warranty I've found was 18 months/18K miles parts/labor. Shortest, 1 year/ 10K miles.
A used trans is the easiest pill to swallow, but a gamble. Qyota got pretty lucky and got his warrantied:
"As suggested, the cheaper route is to get a donor. I got one with 78K installed a few months ago. $600 for the tranny with a 1 year parts/labor warranty, and another $600 to have it installed (including new filter, fluid and a new seal)."
Pulling the donor trans seems like a big job. If you could pull it, you could probably install it. If you ordered one that's already pulled, you won't know whether it was pulled because of the pink milkshake. A warranty is mandatory.
4runners are not common here, and we don't find them sitting around at junkyards with low miles and good transmissions.
As far as remanufactured. Right now McGeorge Toyota is selling remanufactured transmissions for $2,370. That is for local pickup only, + $1,000 core charge, + tax. You might be able to sweet talk a dealer near you into getting near it. They probably will not match it. With the cheapest labor I was quoted, we're talking out the door price $3,500 for a remanufactured transmission and install. I paid $4,000 for the 4runner.
If your 4runner is low miles, and you can DIY, and borrow a friend from time to time, and had a nice comfortable garage to work in, I'd go with a remanufactured trans. In my case, pushing 280K, I'm going to end up selling it. Other things will start to go bad over time. Head gasket to name one.
