Old 04-01-2010, 06:39 PM #1
FoneRunner's Avatar
FoneRunner FoneRunner is offline
FoneRunner is on a distinguished road
FoneRunner's Avatar
Longer lugs up front
So I'm now running the FJ80 rims with 1/4" spacers and the lug nuts barely have anything to grab. Longer lugs? If so where and how?
'98 4Runner Limited Desert Dune 4WD lifted, locked, TJM'd, OME'd, LC'd, LED'd, ACC'd, CB'd, Gobi, Hilux'd, JDM'd, etc...
'98 Tacoma SR5 slightly built, '15 4Runner TEP
FoneRunner is offline   Reply With QuoteReply With Quote
Old 04-02-2010, 09:03 AM #2
bak3rme's Avatar
bak3rme bak3rme is offline
bak3rme is on a distinguished road
bak3rme's Avatar
Bump
'99 SR5 3.4L 2WD
SOLD
Build Thread
2003 Nissan 350z Track/Autocross
2014 4runner SR5
bak3rme is offline   Reply With QuoteReply With Quote
Old 04-02-2010, 10:04 AM #3
xskydivingdudex's Avatar
xskydivingdudex xskydivingdudex is offline
xskydivingdudex is on a distinguished road
hmm thats interesting.. I know BAJArunner on YT was trying to extend his lugs not too long ago but not sure if he did it or not.
| G3 Projectors | OME/LC | 315/75 Kelly Safari TSR | Custom LC Rims | Rola Vortex Roof Rack | Gobi Ladder |
xskydivingdudex is offline   Reply With QuoteReply With Quote
Old 04-05-2010, 06:13 PM #4
FoneRunner's Avatar
FoneRunner's Avatar
All the way to page 5 to bump this thread...wow!
Old 04-05-2010, 07:30 PM #5
Elton H's Avatar
Elton H Elton H is offline
Elton H is on a distinguished road
Elton H's Avatar
why you need 1/4'' spacers ?
98 4runner sr5 3.4L 5spd 4x4 e-locker sold 10/2/11
07 tundra 5.7L 4x4 limited dc was my moms r.i.p 3/19/11
Oregon Toyota Owners Club
Elton H is offline   Reply With QuoteReply With Quote
Old 04-05-2010, 07:38 PM #6
Duhockey's Avatar
Duhockey Duhockey is offline
Duhockey will become famous soon enough
Duhockey's Avatar
cuz hes running LandCruiser wheels
07 SR5 V8 Build Thread
Jayden- "Jeeps don't go 4wheeling!"
In Colorado or coming out to 4wheel? Check out RM4x4.org
Duhockey is offline   Reply With QuoteReply With Quote
Old 04-05-2010, 07:42 PM #7
Elton H's Avatar
Elton H's Avatar
hmm thought they had a better backspaceing than stock
Old 04-05-2010, 07:53 PM #8
theizzardking's Avatar
theizzardking theizzardking is offline
theizzardking will become famous soon enough
can't you just pop the studs out and get a piece of threaded rod and cut to fit?
if you can't pop the studs out and they are fixed to the hub you can grind the old ones off and tac new ones on.
really that's your only options unless they make longer ones, again back spacing may help as well, but the only chance you got to make the studs long is to replace.
'76 FJ40, '87 4runner, '98 LC 100, 99 4runner,'02 Tundra,'02 LX470,'08 Tacoma Dbl cab,'09 LC200, '16 Trail Premium. also 76 super beattle,'06 XR650L,'18 Triumph Scrambler-XE.
theizzardking is offline   Reply With QuoteReply With Quote
Old 04-05-2010, 07:58 PM #9
FoneRunner's Avatar
FoneRunner's Avatar
I don't think I would have to have the spacers if it weren't for the 199mm calipers...they have a snaggletooth that bites the back side of the LC rim. I dug out a pretty good groove...the spacers would have prevented that. they're only 1/4" spacers...the guys at the tire shop said to get longer studs. Just wondering if anybody here has ever done that....
Old 04-05-2010, 08:01 PM #10
is this about your spacers if so you can just get a thread pitch guage out and check the pitch of thread and the diam of the bolt and order some threaded rod.
that's also zinc plated so make sure you ordered the same thing other wise it will rust out sooner.
check here
McMaster-Carr
they should have what you need.
seriously though your fine with only 8 threads just make sure you use a tq wrench on it so it won't back off, as far as strength goes your good.
me and the 10 engineers sitting around me all confirm that's fine.
Old 04-05-2010, 08:02 PM #11
i think with the brake upgrade your meant to grind a corner off the caliper it's self, it's a cast part and won;t miss a little metal ground off the corner......
Old 04-05-2010, 08:15 PM #12
FoneRunner's Avatar
FoneRunner's Avatar
Somebody could have mentioned grinding off the snaggletooth! Oh well...I'm not sure it's grabbing 8 threads...maybe 4....but I don't have a good way of telling for sure. The tire guys looked concerned...but I've put 4 or 5k miles on it this way so I guess it'll be ok.
Old 04-06-2010, 12:03 PM #13
yeah if they make longer studs i'd just get them for peace of mind, i've never ran these spacers so i don't know how the studs are attached to the hub, but from what they were saying sounds like you can just buy some longer studs, just do that and be done with it.
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
