04-03-2010, 08:07 PM
Problem with starting warm 1999 - Update, problem still exists
I just bought a 1999 V6 runner with 163k. When I was test driving it at the dealer it started immediately when it was cold, but after shutting it off and letting it sit for 20 min or so it stalled a few times before it would start. The fuel light was on and it was parked on an angle so I thought that it had something to do with being low on fuel.
Its been 4 days and it did it again today. Started it cold at home and drove about 10 min before shutting off. Restarted about 5 min later and it took me 3 tries to get it to idle and then it was fine.
Other than that it runs great and idles fine. Cold starts are not an issue, just the warm ones. It feels like its starving for fuel. I picked up new plugs as they need to be replaced anyway and a few filter. I did a little research and it looks like the idle air control valve may need a cleaning.
Any other thoughts? There is no warranty from the dealer, however they do offer a 5 day return policy and I have one day left. I dont want to return because other than that I really like the truck. plus I already paid $200 to have tires swapped over.
Problem with starting warm 1999 V6
Other than that it runs great and idles fine. Cold starts are not an issue, just the warm ones. It feels like its starving for fuel. I picked up new plugs as they need to be replaced anyway and a fuel filter. I did a little research and it looks like the idle air control valve may need a cleaning.
04-03-2010, 09:54 PM
Start with the cleaning the IAC and throttle body.
2021 Tacoma 4x4 TRD Off Road Double Cab Short Bed (my DD)
2017 4Runner 4x4 Limited (the wife’s)
04-04-2010, 11:37 PM
Well, I picked up some seafoam and was going to clean everything out but I got a call back from the delear. They said to bring it in and they would take care of the issue.
On another note, I did replace the PCV valve today without choice. I was looking under the hood and noticed a bunch of whirlybirds on the intake manifold on the pass side. Was trying to vacume them out and tried to disconnect the PCV hose to get a better angle. Well, I gave it a few tugs and the little bas**** broke off. Tried to pull it out with plyers and it started to just break apart. I got nervous and took my time removing the intake to get a better angle and finally got it out.
Good times!
04-13-2010, 02:10 PM
Well, imagine this... The delear said they could not duplicate the problem.
Yesterday I went ahead and removed the throttle body and ICV valve. Throttle body was pretty nasty as well as the port for the ICV valve. Aside from the coolant passages, all surfaces were coated with carbon.
I am a little concerned as I disassembled the little green magnet box deal on the ICV valve when I was cleaning it out. I cleaned off all the old sealant material and re-sealed with sensor safe high temp RTV. I am hoping I didnt screw anything up.
Anyway, both gaskets were a little distorted so I had to order new ones and should be in today. I hate waiting for parts when you want to get things back together to make sure things run right.
I hope this fixes my problem. I hope this fixes my issue, I had a Cherokee with a starting problem. It was hard to start when cold so I replaced the fuel pump, R&R'd T-body to clean it, seafoamed, complete tune, etc and never fixed the issue. Finally sold it.
04-13-2010, 06:38 PM
Update -
Got everything back together and was a little worried at first. Started the truck and it fired immediately, but would idle at 1500 rpms in park and 1100 in drive. So I drove it around a bit and the idle slowly dropped back down to a little higher than what it used to be.
I assume this is somewhat normal since everything was disconnected including the battery? Does the computer have to relearn itself?
Anyway, shut it off and restarted it about 20 min later and guess what, problem is still there. It will start, but its almost as if its not getting enough fuel or something. Kinda sputters to life. Once its started its fine.
Any other ideas?
Maybe I will just live with the issue.
04-13-2010, 09:11 PM
i seem to gt this problem rarly so im ignoring it. i may try cleaning the throtle body and run some seafoam
as for the idle, your tuck will idle higher when the engine is cold
04-14-2010, 03:26 PM
Yea, but it was higher and longer than normal. It was 60 degrees yesterday and the truck idled for a while.
I will give it some time and see how it does.
04-14-2010, 03:47 PM
You probably need a fuel filter sir.. That sitting on the incline possibly shifted any loose junk in the tank close to the pick up and shot it thru the lines
1994 6766 Supra SOLD
2001 SR5 Sport 4WD, AR JR intake, Tundra 5100s, TRD springs, 890s, LC shocks
2005 GX470
2008 USB ISF
ARMY AVIATION
04-14-2010, 09:03 PM
I almost replaced the fuel filter, actually bought a Wix from Baxter. Anyway, the dealer recommended against it saying that unless it was absolutely necessary its not worth replacing do the the possibility of leaks.
04-14-2010, 09:42 PM
That's a new one. The change interval for the fuel filter was left out of the owner's manual so there's a joke that it's a lifetime filter, but I changed mine before. It took me like 20-30 min IIRC and no leaks.
04-15-2010, 12:09 AM
^^ Yea, I was wondering.
Did you install a factory filter or aftermarket?
Any pointers? Looks like there is a plastic type skidplate that needs to be removed to expose the filter.
04-15-2010, 12:49 AM
Nope, there shouldn't be anything in the way. It's just right under the drivers side floorpan.
I bought a factory filter from shoptrd.com. I spent $30 on it, and wish I would have just gotten an aftermarket one for half that much. Like Brian said, it's a very simple job. Easier than changing oil, unless you've got rust. Then it might be a pain.
Here's a nifty little writeup. http://www.4runners.org/writeups/fuelfilter/index.html
2001 SR5~Thundercloud Metallic~3.4L Auto~4x4~260k miles~TRD 2gen black Supercharger~URD AFR Calibrator~B&M 70264~Bilstein Adjustable w/ tall '99 fronts~ProComp 3" rear springs~Nitto Ridge Grappler 285/70R17's on 17x9 Enduro's~Yakima RailRider w/48" bars~ScanGauge II
04-15-2010, 03:59 PM
I've heard that the aftermarket ones may have a different thread pitch causing possible leak issues.
Oh, well. I was on Amazon ordering some B-day presents for the wife and they had a Mann filter for $12 with free super saver shipping. I know when I had my BMW Mann was a big name and made quality products so I assume it should be okay for the 4runner. Hey, if it doesnt fit its $12.
04-15-2010, 04:06 PM
Samething in the Supra world. Lifetime fuel filter my A$$ they do get clogged and do need changing!
Let us know the results!
2005 GX470
2008 USB ISF
ARMY AVIATION
