Old 04-08-2010, 10:45 PM #1
49Runner 49Runner is offline
49Runner will become famous soon enough
New 3rd Gen To Do List
Picked up a 97 Limited with rear locker w/175k on it about 3 weeks ago.
Things I know I need to replace or repair... rear springs, turn rotors, new pads, new tires and timing belt (to be safe).
Any other suggestions to add to the short list?
Note: I know I could search but I'm looking for real time advice...
Thx
49Runner is offline   Reply With QuoteReply With Quote
Old 04-08-2010, 11:08 PM #2
brian2sun's Avatar
brian2sun brian2sun is offline
brian2sun has a spectacular aura about brian2sun has a spectacular aura about
brian2sun's Avatar
Welcome to the forum. I'd suggest trying to get the service history if possible, but if not I would change all the fluids including the diffs (I'm guessing it's 4x4 by the rr diff lock), engine oil, tranny, and coolant. Test the battery, change the plugs/wires (use only NGK or Denso), grease the driveshaft. If you want to get crazy with it, clean the throttle body, IAC and MAF (search if you don't know what they are - there's lots of talk about these and how to clean em). I would go around the engine bay and check all the hoses, and the electrical connections and wiring too.
Congrats and I hope you get many years of driving out of her!
1997 4Runner 4x4 SR5 - Geared, Locked & Armored
**CLICK FOR '97 BUILD THREAD**
2021 Tacoma 4x4 TRD Off Road Double Cab Short Bed (my DD)
2017 4Runner 4x4 Limited (the wife’s)
brian2sun is offline   Reply With QuoteReply With Quote
Old 04-08-2010, 11:12 PM #3
JohnsD90's Avatar
JohnsD90 JohnsD90 is offline
JohnsD90 will become famous soon enough
JohnsD90's Avatar
Bosch is good too for spark plugs. I would replace the steering rack bushings, the Sway bar bushings, and the struts and shocks. That will give you the best bang for your buck. Make sure if the plugs are original you buy spark plug wires too.
JohnsD90 is offline   Reply With QuoteReply With Quote
Old 04-08-2010, 11:18 PM #4
brian2sun's Avatar
brian2sun's Avatar
If Bosch was so good, there wouldn't be a hundred threads about how they aren't. I tried em in mine a while back, but I'm not even gonna post the pic of my Bosch again.
Old 04-08-2010, 11:31 PM #5
JohnsD90's Avatar
JohnsD90's Avatar
We can have DUhockey post a pic of his after 100k miles, I woulda used Bosch in mine but i got 2 bosch plugs after going to 4 different walmart, i just said F this and bought NGK's.
Old 04-08-2010, 11:38 PM #6
rjaudi rjaudi is offline
rjaudi is on a distinguished road
Why do you need new rear springs? If you have no history of the timing belt replacement it would be a good idea to do that and the water pump.
rjaudi is offline   Reply With QuoteReply With Quote
Old 04-08-2010, 11:40 PM #7
JohnsD90's Avatar
JohnsD90's Avatar
Oh, yeah, go to the stealership, see if your rear springs were replaced yet under recall, if not then you get a new set for free.
Old 04-08-2010, 11:41 PM #8
bak3rme's Avatar
bak3rme bak3rme is offline
bak3rme is on a distinguished road
bak3rme's Avatar
probally saying this because lots of 3rd gens have rear sag...they sit lower in the rear than the front, which looks ugly. looks like ur always hauling like 10 kegs of beer in the cargo...which is no good..i think...
changing the springs would level out the car
'99 SR5 3.4L 2WD
SOLD
Build Thread
2003 Nissan 350z Track/Autocross
2014 4runner SR5
bak3rme is offline   Reply With QuoteReply With Quote
Old 04-09-2010, 12:05 AM #9
Yes, if that is the case I wonder if Toyota will still honor the recall for the rear springs on these. My 97 had its rear springs replaced in 2002 for free.
Old 04-09-2010, 12:24 AM #10
bak3rme's Avatar
bak3rme's Avatar
most likely not, you can always check, but thats over a decade ago, so ...yea but u can check!
u can also get used coils from pppl selling on here, or just go to a junkyard!
'99 SR5 3.4L 2WD
SOLD
Build Thread
2014 4runner SR5
Old 04-09-2010, 01:12 AM #11
Let me go through my reasoning for my initial list.
Rear end is soft and bouncing off the bump stops... shocks had been replaced shortly before I purchased. Tried to take it in for the service bulletine... mine was brought in as a Canadian model so they would not honor it. No local used springs, didn't see any available in the classified and I want to stay stock until I figure out the set up I want to go with.
The tires that the previous owner put on are new "E Load" so they are WAY TO STIFF!!!
Front shocks and springs are good to go.
Rotors are warped... either turning or getting new.
The timing belt and water pump (thanks for the reminder) will be replaced pretty quick here.
Thanks for the heads up on the other items... I will work on this list over the next couple of months.
Funny... I just spent about 3k on engine parts to build a high performance motor this past Fall for the car I just sold and told my wife that the 4Runner will be a cheap hobby... now I realize different vehicle same temptations. lol
Old 04-09-2010, 01:37 AM #12
97blkt4r's Avatar
97blkt4r 97blkt4r is offline
97blkt4r is on a distinguished road
97blkt4r's Avatar
I am in the same position you are and told myself the samething when I bought my 4runner (about a month ago). Was planning on keeping it stock and not doing any off-roading, but the temptation is creeping up on me.
97blkt4r is offline   Reply With QuoteReply With Quote
Old 04-09-2010, 10:59 AM #13
kball's Avatar
kball kball is offline
kball is on a distinguished road
kball's Avatar
Get new. Turning just makes them thinner which is worse.
1996 SR5 4Runner V6 4WD Auto
Toytec Ultimate w/ OME 890's plus 1.5" daystar spacer
60028 OME shocks, Goodyear Duratracs 265/75 -16
B&M 70268 with Magnefine filter, 199mm TBU
236K miles
kball is offline   Reply With QuoteReply With Quote
Old 04-09-2010, 11:05 AM #14
Justin727's Avatar
Justin727 Justin727 is offline
Justin727 is on a distinguished road
Justin727's Avatar
You bought the correct plug. DUhockey was probably 1 of the very few that was lucky enough to not have any problems. We've seen it too many times people come back complain about random miss, rough idle, fuel mileage gone, etc etc.
We try to sell them a tune up and they say oh no, so and so down the road did a tune up or they did it themselves. We pull a plug and wala BOSCH!!!
I've worked @ Toyota and seen it too many times and the same here at Nissan now.
John don't chance having to do it twice. Do it right the 1st time
1994 6766 Supra SOLD
2001 SR5 Sport 4WD, AR JR intake, Tundra 5100s, TRD springs, 890s, LC shocks
2005 GX470
2008 USB ISF
ARMY AVIATION
Justin727 is offline   Reply With QuoteReply With Quote
Old 04-09-2010, 11:06 AM #15
JohnsD90's Avatar
JohnsD90's Avatar
Can't its a one time deal....I tried.
