Originally Posted by infamousRNR
hoping for some guidance here...
tried it after i got an alignment and the lights came on... no luck...
recently attempted it again but STILL with no luck...
as i follow the procedure i notice my ABS light flashing but not the TRAC light as stated in the instructions...
so i must not be doing something right...
wish there was a video..
i h8 dash lights..
no CEL, just trac off and vsc
Damn, just read this post 7/5/15 & this morning, 7/6/15, about 5min into my drive to work, my check engine light came on along with my "vsc off" & "vsc/trac" light.
I followed the mike-thompson link after work and I was able to get everything to turn off. But when I cranked up my engine to do a test drive, my "CEL", "vsc off" & "vsc/trac" lights came back on within 1-2minutes of starting the engine. Went through the same process several times with the same results. Didn't have my obd ll scanner handy to run the cel codes.
My ABS light was also flashing along with the vsc/track light. Unfortunately I am in a similar situation looking for a solution. Keep me updated if you come up with anything.
