06-27-2016, 05:01 PM
#526
Moderator
Real Name: Dylan
Moderator
Real Name: Dylan
Originally Posted by Herculean T4R
I like the front bumper. Corey did a great job (as always). Would you mind if Corey makes one for me. I would probably go with thinner steel. - Sunny
Bumper is all my design but he should still have the cut files for it. Its not a simple bolt on design though as it requires a lot of cutting and welding to the frame.
The Rock Turtle Lifted, Locked, Boosted, Armored, TacoBoxed, and awaiting destruction.
06-27-2016, 09:24 PM
#527
Hey, Dylan! It was cool to see the Lobs... er... Turtle in person at RT and check out the updates in person.
I'm starting to think about upgrading the rear shocks on my rig and wanted to ask if you have any build specs / more info on your icons... I was going to ask at RT but you were busy spinning a wrench. Feel free to send a PM.
01-15-2019, 05:28 PM
#528
Real Name: Trevor
Real Name: Trevor
Really great build thread, I've been lurking for a while, I just picked up a 97 4runner it's my second 3rd gen and is gone stock this thread has definitely got me thinking.
Cheers!
02-07-2019, 12:07 AM
#529
Real Name: Roman Schnobrich
Man, what a great build thread. Just put off homework for two hours being puzzled by your Marlin Crawler setup, as well as that snail setup. I go to school up in Bozeman, MT and my roommmate said he met you while getting a tour of the Earthroamer HQ. Thanks for all the inspiration, Dylan!
11-22-2021, 12:49 PM
#530
Originally Posted by steezemcqueen
Looks like its time for some new plugs
The 3 on the left are from the driver side head and the ones on the right are the passenger side head. The driver side head plugs will wear faster due to the waste spark system but i didn't think the difference would be as drastic. I have about 35k miles on these plugs which are the Denso IK22's. Not super happy with the life but it could be worse. I couldn't find any IK22's locally and i didn't want to run these any longer so i just replaced them with some 2 step colder NGK copper plugs. We will see how long those last but i'll probably swap them from side to side after 15k or so.
Old post but do you see that as average for spark plug life? I’m shopping for a 3rd gen runner and I’m one of the adds the guy listed out like 8 years worth of service and it seemed like he was replacing spark plugs every 2 years. That seemed a little frequent but I don’t know what kind of mileage was put on the truck in those intervals or the reputation of his mechanic/his level of OCD.
11-22-2021, 01:04 PM
#531
Real Name: Patrick
Real Name: Patrick
The 5vz is a waste spark ignition system so each spark plug pulses twice per 4 stroke cycle. Recommended service period is every 30k miles and use dual electrode spark plugs. (Supercharged owners normally use a single electrode spark plug that is 2 steps colder to help with knock.)
11-22-2021, 01:20 PM
#532
Thanks man, I ended up seeing the factory interval a couple posts down from the one I quoted but, I’ve got a better chance of it sticking in my 🧠 now that I’ve read it a couple of times. 👍🏼
11-22-2021, 01:34 PM
#533
I replaced mine as part of comprehensive baseline maintenance when I purchased in 2010. Since then, I've put 48k on...guess it might be time to check the plugs. Now has 224k. The most significant "failure" in my ownership has been starter motor contacts which were replaced @ 199k.
Sounds like you probably can't go wrong buying that one.
'97 SR5 V6 4x4 | 5-speed | e-locker | 33's
11-22-2021, 01:41 PM
#534
Yeah the hardest part at this point is trying to decide if I hold out for a unicorn or just get something decent and go from there. I had an 03 🌮 TRD 5 speed and loved it. The 🦄 4Runner would be White 5speed elocker jshift t case and sub 200k miles but I’m noticing that might be easier said than done. I just need to try to be patient and not too impulsive, I found one that checks all those boxes but the locker…
11-22-2021, 10:28 PM
#535
Sounds like a tall order indeed. When I got mine, the miles were easier to achieve, but getting the 5speed elocker jshift combo took a while to find. I probably looked at a dozen before I found it.
11-23-2021, 12:22 AM
#536
Yeah I’ve been scouring Craigslist, fb marketplace and now the classifieds here, I’ve found a couple that are like 95% and I’m starting to think that might be the route to go, I can always add a locker considering I plan to lock the front what’s another diff open while I’m at it 🤷*♂️
11-23-2021, 09:39 AM
#537
Real Name: Patrick
Real Name: Patrick
A locker is the easiest thing to change compared to repainting a car to the color you want or doing a manual swap
11-23-2021, 10:38 AM
#538
Yeah, I don’t like all the computer nonsense or having to add pedal buckets, but there will definitely be some amount of trans tunnel work as I plan to add a 🌮 📦 when either Marlin has the adapters available again or I’m able to find a used unit or the adapters. I’m kind of hoping after I find the 4Runner I’ll find someone that’s transitioning from a sturdy mild built rig to extreme build and I can get the 🌮 📦, drive shafts and front locked diff to just drop in. Dream big right 😂
04-19-2023, 11:04 PM
#539
Real Name: Jeff
Real Name: Jeff
Bump…
3RDGENS.COM
My Video's
'96 Limited - October '08 T4R Of The Month (Sold)
'00 SR5 - Lifted/Supercharged/E-locker
'16 SR5 Barcelona Red
