04-26-2010, 11:44 PM
So explain elockers to me
Let me see if I got this straight...A stock 4wd t4r comes with only a rear diff lock, right? So the elocker is used on the front diff?
04-27-2010, 12:05 AM
ehh no the e locker is the rear diff lock
98 4runner sr5 3.4L 5spd 4x4 e-locker sold 10/2/11
07 tundra 5.7L 4x4 limited dc was my moms r.i.p 3/19/11
Oregon Toyota Owners Club
04-27-2010, 12:16 AM
ELocker says it can be used on the rear or the front diff. What's the advantage of replacing the stock diff lock with an elocker on the rear diff then?
04-27-2010, 12:18 AM
Most 4x4's didnt have the E locker. The E locker and Diff lock are the same thing, and they were only available on the rear axle from 96 to 00. Never on the front.
04-27-2010, 12:19 AM
Both diff's are "open" on 4runners. So if you have the elocker it will lock up the two back wheels. With open diff's once a wheel loses traction it will just spin and the other wheel on that diff will sit there. With the elocker both rear tires will spin even if one is off the ground because it's locked. To put it simply, 4 wheel drive is really two wheel drive and if you have the elocker you have 3 wheel drive.
1996 SR5 4Runner V6 4WD Auto
Toytec Ultimate w/ OME 890's plus 1.5" daystar spacer
60028 OME shocks, Goodyear Duratracs 265/75 -16
B&M 70268 with Magnefine filter, 199mm TBU
236K miles
04-27-2010, 12:51 AM
This is interesting as I have met many people that have no idea what the E-locker/rear diff lock is or does. Would be nice to put together a demonstration video to make it easy.
2000 4RUNNER SR5 TRD Supercharger, OME 882's w/ topout's and n91sport strut up front.OME 851's w/ cones and trekmaster LC shocks in the rear. R.I. LED lighting, retrofit E locker, 1" diff drop, 315/75/16 cooper discoverer STT, 2" R.B. body lift, rear disc brake conversion, Ingen intake, Spectre cone filter, Fitch fuel cat, Cobra LTD29 CB, custom front, and rear bumper, smittybuilt 8000 # winch, 66" 4xinovations rock sliders w/kickout, lil skip's gas tank skid. Custom skid plates. My build thread is @ http://www.toyota-4runner.org/3rd-ge...ld-thread.html
04-27-2010, 12:53 AM
This I already understood.
I've just been reading through all the threads and it seems like a lot of people have an elocker mod. I assumed that all 4wd T4R's came stock with a rear diff lock and didn't know why someone would replace the stock diff lock with an elocker. Then I thought that maybe they were putting it on the front diff so they had all four wheels locked when needed.
So basically, the people that added on an elocker didn't have a rear diff lock to begin with?
04-27-2010, 12:55 AM
Yes, but the amount of people than have done that mod probably wouldnt fill up a schoolbus.
Bingo!
2001 SR5~Thundercloud Metallic~3.4L Auto~4x4~260k miles~TRD 2gen black Supercharger~URD AFR Calibrator~B&M 70264~Bilstein Adjustable w/ tall '99 fronts~ProComp 3" rear springs~Nitto Ridge Grappler 285/70R17's on 17x9 Enduro's~Yakima RailRider w/48" bars~ScanGauge II
04-27-2010, 01:04 AM
So basically, the people that added on an elocker didn't have a rear diff lock to begin with?[/QUOTE]
Correct that is what i did, retro fit as the diff lock/ e-locker was only available 96-00 and as far as I know only on the limited, and maybe some highlander 4X4 packages it is rather rare but very sought after in the off road world. As far as I know the only selectable locker for the front diff is ARB air locker but I may be wrong.
my runner had all the wiring through out the dash so all I had to do was find the rear end, the switch, and the ecu, install them and make a wire harness from the ecu the the rear end and now it works just as if it was factory installed.
04-27-2010, 08:51 AM
you mentioned the diff lock/ e-locker was only available 96-00 and maybe only on limited or highlander models. i have an 01 SR5 with the diff lock, came stock form the manufacturer that way. i too thought that this was std for 4WD runners. this appears to not be so...is this a rarety?
2001 Toyota 4Runner SR5 4WD Thunder Cloud w/ Gray Interior - AEM Brute Force Intake - Westin Nerf Bars - Yakima Load Warrior w/ Kayak Stacker - OME 881 Front Coils - OME N 90004 Front Shocks - OME 890 3" Lift Rear Coils - OME 60027 Rear Shocks - One Inch Diff. Drop - Tru-Cool 4454 Aux. Cooler - Polyurethane Sway Bar Bushings Front & Rear - WeatherTech Floor & Cargo Mats
04-27-2010, 09:09 AM
maybe I'm wrong and don't have the rear diff. i have the center differential (difference?)
04-27-2010, 11:03 AM
The rear locker was not available in 2001. What you have a center diff lock. Different thing entirely.
When the center diff lock is "on" it just gives you "conventional" 4wd with the front and rear driveshafts locked together. With the center diff lock in the "off" position, you can drive in 4wd on the streets (basically, you have AWD) which I can't do on my 99 because I don't have a center differential.
And FWIW you don't have to have a limited to get a rear diff lock. My 99 SR5 has a rear locker.
Martin AKA Zapp Branigan - No longer a 4runner owner!
04-27-2010, 11:07 AM
Guys, I think Domstriker is talking about the "E Lock Mod." A/K/A the Gray wire mod (Tacoma) or Green Wire Mod (4runner.)
DOM: As it comes from the factory, the Toyota e-locker can only be engaged in 4wd low range. If you put the T-case into 4high or 2high, the E-locker automatically disengages. However, there is a modification you can make that will allow the factory E-locker to work in 4high or 2high, it's sometimes called the gray wire mod, or the green wire mod. I haven't done it yet, but it's quite common in the Toyota world.
Does that help?
04-27-2010, 11:19 AM
Does that help?
yes that helps immensely. Although I'm realizing that there's more to this topic than I originally thought.
