Old 05-21-2010, 12:24 PM #1
Whiplash Willy's Avatar
Whiplash Willy Whiplash Willy is offline
Whiplash Willy is on a distinguished road
Creating A Maitenance Spreadsheet
I want to create a maintenance spreadsheet in excel, so I can start keeping track of all of the maintenance I have done, and when the next interval will be due. I have had my 4runner for a few weeks now, with 98k mi on it, and have no maintenance records on it, so I will be starting from scratch.
Can anyone point me in the direction of some good resources for what maintenance needs to be done, and at what interval. I can share the spreadsheet with everyone once it is done!
Whiplash Willy is offline   Reply With QuoteReply With Quote
Old 05-21-2010, 12:36 PM #2
denverunner's Avatar
denverunner denverunner is offline
Real Name: Kyle
denverunner is on a distinguished road
Real Name: Kyle
I use the Toyota Owners Website
Its great for keeping track of the work you've done. Create an account, it's free. Doesn't matter if you service your vehicle at a dealer or not. You can manually add your records and if you decide to have your 4R serviced at the dealer, your profile automatically be updated, I think.
EDIT: On that same website, you will find all of the recommended services and suggested intervals for maintaining your 4R. Go here for FSM.
98 4Runner / 5 spd / 3.4L
98 Civic HX / 5 spd / 1.6L
denverunner is offline   Reply With QuoteReply With Quote
Old 05-21-2010, 12:57 PM #3
TheDurk's Avatar
TheDurk TheDurk is offline
TheDurk is just really nice TheDurk is just really nice TheDurk is just really nice TheDurk is just really nice
TheDurk's Avatar
I just have a 4 column spreadsheet going back to '99. Date/Miles/Work/Receipt. The last is a one bit Y/N field to show whether a receipt is in the folder. I don't keep fluid and filter receipts once I am out of warranty; I have a stock of both and it would be meaningless. Plus things like MAF cleanings and brake bleedings don't generate receipts.
I don't track to intervals for groups of items because I don't do everything at once. After 10 years, gear oil and coolant may both be at 30K intervals, but those are now 10k apart for one reason or another. So I just look at the record and figure out what needs to be done next and I do it when I can. Oil and tire rotation I pay close attention to. The rest is plus or minus 5K so I can do it in nice weather. I make a list in the Spring and try to finish it by Fall.
My Backyard Frame Swap
Old 05-21-2010, 01:24 PM #4
brian2sun's Avatar
brian2sun brian2sun is offline
brian2sun will become famous soon enough brian2sun will become famous soon enough
brian2sun's Avatar
I seperated my work log into 3 sections:
1) Stuff that I did/stuff I need to do according to mileage (in order of soonest to perform).
2) Stuff I have done because it broke/wore out (A-Z).
3) Little stuff to do whenever I get a chance (like replacing my door light triggers).
1997 White SR5 4x4 on 35s w/ 4.88s, Lockers & Armor
**CLICK FOR '97 BUILD THREAD**
2016 Magnetic Gray Metallic SR5 4x4 (NEW!)
brian2sun is offline   Reply With QuoteReply With Quote
Old 05-21-2010, 03:02 PM #5
Maxil's Avatar
Maxil Maxil is offline
Maxil is on a distinguished road
Maxil's Avatar
I am in the same boat, just got mine with 96k on it and not sure of some of the maintenence. The oil and plugs are fine, however I am replacing the differential fluids and transfer case asap. I also plan to change the transmission fluid when able along with a MAF cleaning, I here that can make a big difference. I figure anything that is reasonable to do I want to go ahead and do it.
Maxil
98' SR5 4x4
Yaesu FT-8900 with Larsen NMO 150 Antenna
K&N Cold air intake
Koyo Radiator with B&M 70264 for towing
Amsoil fluid everywhere, except Radiator
Maxil is offline   Reply With QuoteReply With Quote
Old 05-21-2010, 04:48 PM #6
TheDurk's Avatar
TheDurk's Avatar
I tried that split between 1 & 2 on previous cars but I gave up. When something breaks, I end up doing as much needed maintenance as I can in the vicinity. Frozen e-brake bellcrank leads to clean, lube and adjust rear brakes (yikes, they need it and drum is off), flush brake fluid (oo--it was icky) and rotate tires (well, two are off). I applaud your intent but I am too disorganized to do it that way.
Old 05-21-2010, 06:40 PM #7
brian2sun's Avatar
brian2sun's Avatar
I try to keep it organized, but it doesn't always work out like that. I will also usually try to take care of everything in an area even if it's not necessarily time to do each item yet - I think that is wise and probably saves a lot of effort in the long run.
I'll also adjust some of the mileage intervals so I can bang out several items in one shot. Like if I'm due to change my oil at 180K, rotate my tires at 182K and grease my driveline at 179K, I'll just do all 3 at 181K or something. I just make sure that nothing is going too far past the recommended interval.
Old 05-22-2010, 09:02 AM #8
004Gunner's Avatar
004Gunner 004Gunner is offline
Registered User
004Gunner is on a distinguished road
Registered User
004Gunner's Avatar
If you have office '07 then try this. I use it for my fiancee's car and my runner. There are a lot of templates on the Microsoft Office site so I would suggest you search there before creating your own. I like the fact that you can have different worksheets for each vehicle in Excel, otherwise I would just create a table in Word.
004Gunner is offline   Reply With QuoteReply With Quote
Old 05-22-2010, 09:15 PM #9
notrayray's Avatar
notrayray notrayray is offline
notrayray is on a distinguished road
notrayray's Avatar
I use this....
MyCar-Monitor - Free software downloads and software reviews - CNET Download.com
2001 M. Silver 4WD SR5 5VZ Love Machine
3rd Gen FAQ Here
notrayray is offline   Reply With QuoteReply With Quote
Old 05-22-2010, 10:25 PM #10
Elton H's Avatar
Elton H Elton H is offline
Elton H is on a distinguished road
Elton H's Avatar
at 100k id start thinking about the timing belt and water pump sure you could let it go a little longer but not too long
98 4runner sr5 3.4L 5spd 4x4 e-locker sold 10/2/11
07 tundra 5.7L 4x4 limited dc was my moms r.i.p 3/19/11
Oregon Toyota Owners Club
Elton H is offline   Reply With QuoteReply With Quote
Old 05-23-2010, 02:15 AM #11
notrayray's Avatar
notrayray's Avatar
clean the MAF
water pump
timing belt
thermostat
pcv valve
lube chassis
retorque driveshaft bolts
air filter
drive belts
spark plugs (every 30,000)
diff fluids changed
trans flush or fluid change (auto - manual)
ps fluid flush
fuel filter
steering rack bushings
check your brakes for wear
3rd Gen FAQ Here
Old 05-23-2010, 01:33 PM #12
bigtimeweb's Avatar
bigtimeweb bigtimeweb is offline
bigtimeweb is on a distinguished road
bigtimeweb's Avatar
Whats the correct torque?
bigtimeweb is offline   Reply With QuoteReply With Quote
Old 05-23-2010, 10:24 PM #13
notrayray's Avatar
notrayray's Avatar
1996 to 2002 Toyota 4Runner OEM Repair and Wiring Manuals
http://www.ncttora.com/fsm/1996/SIL/.../pr/torspe.pdf
54 ft/lb's
3rd Gen FAQ Here
Old 05-23-2010, 11:36 PM #14
bgmac's Avatar
bgmac bgmac is offline
bgmac is on a distinguished road
bgmac's Avatar
Look, I believe in preventative maintenance as well but seriously......spreadsheets????
98 4Runner Limited,265/75/16 Hankook Dynapros, KMC XD Black Hoss Wheels, Hella 500, Tokico, PP 1" Springs, Optima Red 34R, K&N, JL, Kenwood
bgmac is offline   Reply With QuoteReply With Quote
Old 03-17-2020, 09:03 PM #15
Meherg Meherg is offline
Meherg is on a distinguished road
lifetime powertrain warranty...they give it for free because only 1 in 1000 will follow thru , keep the vehicle forever, and do and document the required maintenance..."I AM THAT ONE " !
Meherg is offline   Reply With QuoteReply With Quote
