Thread Tools Rating: Thread Rating: 53 votes, 4.85 average. Display Modes
Old 06-01-2010, 08:12 PM #16
SamSter0077's Avatar
SamSter0077 SamSter0077 is offline
SamSter0077 is on a distinguished road
Great Thread, thank you so much!
SamSter0077 is offline   Reply With QuoteReply With Quote
Old 06-03-2010, 08:13 PM #17
CO_FlyFisher's Avatar
CO_FlyFisher CO_FlyFisher is offline
CO_FlyFisher is on a distinguished road
Nice work! I know more than one of us who has spent countless hours trying to figure this all out for their rig. Great write-up!!!
“Engineers don’t idle well.”
'99 Limited 4WD
Upgrades: BFG AT T/A KO 265/75/16, Husky floor liners, WeatherTech window deflectors, Silverstar Ultra headlights, TaskLED Dome lights, Red & White LED maplights, LED tails & 3rd brake light, 35% tinted front windows, TrueFlow air fliter, hardwired V1, Scion T1807 HU w/ Aux input, Masterflow MF1052 in rear side storage
Mods: Deckplate/ISR, independent fog light control, rear diff breather, constant hot 12v outlets, seat-mounted LED Maglite
CO_FlyFisher is offline   Reply With QuoteReply With Quote
Old 06-04-2010, 03:07 PM #18
Reina's Avatar
Reina Reina is offline
Reina is on a distinguished road
Reina's Avatar
Great write-up!!!! answer most of my questions about lifts
98 4Runner V6 Manual 4WD SR5
https://www.facebook.com/masterjho
Automotive Tech ASE Certified Master Tech
Aviation Tech A&P rated
Reina is offline   Reply With QuoteReply With Quote
Old 06-04-2010, 03:24 PM #19
steezemcqueen's Avatar
steezemcqueen steezemcqueen is offline
Moderator
Real Name: Dylan
steezemcqueen will become famous soon enough steezemcqueen will become famous soon enough
Moderator
Real Name: Dylan
thanks to everyone who contributed! i am going to do some more work on it when i got some free time this weekend
The Rock Turtle Lifted, Locked, Boosted, Armored, TacoBoxed, and awaiting destruction.
steezemcqueen is offline   Reply With QuoteReply With Quote
Old 06-04-2010, 03:48 PM #20
kregg's Avatar
kregg kregg is offline
Real Name: Chris
kregg will become famous soon enough
kregg's Avatar
Real Name: Chris
We need to add an "ammendment" about what size tires/rims work with what lifts too...
1996 Toyota 4Runner "UnLimited"
kregg is offline   Reply With QuoteReply With Quote
Old 06-15-2010, 04:17 AM #21
99yota4's Avatar
99yota4 99yota4 is offline
99yota4 is on a distinguished road
99yota4's Avatar
We should also get some info on recommended shocks for various lifts. I'm still trying to figure out what to use with my tall 9 wraps coils when I do put them in. or even with the 8 wraps. I'm thinking just OEM land cruiser shocks should do the job, but i've seen OME, Monroe, and Bilsteins (5100, 5125, 5150) so I am really not sure what to go with. As for the front with TRD tundra, I think i'm going to use the bilstein adjustable 5100. I have the tacoma 5100 so that might not be the best, maybe and when i have enough money to spend i'll try and upgrade to the tundra application of the adjustable 5100 to see if that creates a better ride.
[99 T4R sr5 "highlander" 4wd][Deck plate mod][Clear corner/signals][Tundra/Sequoia Skid][Sound&Security upgrade][TRD Tundra/FJ80 LC coil lift][Tint][01-02 tail lights][14" Magnaflow]
Future mods***
[ISR mod][LED interior]
99yota4 is offline   Reply With QuoteReply With Quote
Old 06-16-2010, 10:22 AM #22
jsmarine's Avatar
jsmarine jsmarine is offline
jsmarine is on a distinguished road
jsmarine's Avatar
Does anyone know if the 2005-2010 Tacoma (prerunner or 4wd) front coils will work on the front of a 3rd gen?
My 4runner - Sold: http://www.toyota-4runner.org/3rd-ge...lots-pics.html
Current Build: 2005 Toyota Tacoma, Crew Cab SB 4x4 http://www.tacomaworld.com/forum/2nd...ld-thread.html
jsmarine is offline   Reply With QuoteReply With Quote
Old 06-17-2010, 05:02 PM #23
Polish Power's Avatar
Polish Power Polish Power is offline
Polish Power is an unknown quantity at this point
What are these aftermarket upper control arms you speak of? I've got an OME lift on mine, and since installing it I've had problems getting the correct camber on the passenger side wheel. The cam bolt is turned as far as it will go, and its still about 1deg out, based on firestones readings. I did a search for some aftermarket control arms, but couldn't find anything.
Polish Power is offline   Reply With QuoteReply With Quote
Old 08-03-2010, 12:02 AM #24
CarolinaCowboy's Avatar
CarolinaCowboy CarolinaCowboy is offline
CarolinaCowboy is on a distinguished road
So I have some last minute questions about the Toytec lift I'm preparing to order at the end of the week.
For the front lift:
I know I want the Coilovers with Bilstein 5100 shocks for the front but are these Coilovers...
ToyTec coilover kit with Bilstein 5100 shocks
...the same as these Coilovers?
ToyTec Coil Overs (95.5-04 Taco & 96-02 4RUN)
-My assumption is that the former is simply the disassembled version of the later, and with the unassembled version I would use my own stock top plates. Correct?
-Also, with the unassembled version it seems the coils only come in silver... which leads me to believe they are the 4cyl light 500lb coils shown as one of the options for the assembled Coilover. I have the 6cyl so I assume I'll need the med 600lb coils (which come standard in red), correct? Anyone know which lb coil comes with the unassembled Coilover?
For the rear shocks:
Can anyone explain the big difference between the ProComp ES9000 ($100), OME 60027 ($180), & Bilstein 5125 ($200) shocks?
-My thinking here is if I can "custom" order the ToyTec Ultimate Kit by ordering everything separate & assembling the coilovers myself then I could use the saved money to upgrade from the ProComps to either the OMEs or Bilsteins. But what is the advantage of each of the upgrades?
1998 Toyota 4Runner SR5 - V6 3.4L - Auto 4x4 (F) Toytec Adj Bilstein Coilovers, (R) 97' 8wrap LC coils & Bilstein 5125s, 305/70R16 KM2s, Spidertrax wheel spacers, 2" 4crawler BL, PIAA 520 ATPs, Yakima Rack, Pioneer Audio, K&N Drop-in, Deckplate & ISR Mod, 14" Magnaflow Exhaust Build Thread
**On The Way**...TRD decal; Aux Light Switch; Panhard Drop Bracket
**Planned**... ProComp 8069s; 4xInnov sliders; Flowmaster 40 or Cherry Bomb Glasspack; Tundra 231mm brakes; HIDs; CB radio; Cargo rack; Window tint
CarolinaCowboy is offline   Reply With QuoteReply With Quote
Old 08-03-2010, 11:21 PM #25
Moderator
Real Name: Dylan
Moderator
Real Name: Dylan
For the front lift:
yes and no. the assembled shock uses a Bilstein 6930 and the unassembled uses a D558. the D558 is was originally made for a tacoma so it is valved a little softer and the 6930 was originally a tundra shock so it is slightly firmer. the 6930 also uses our custom flex mount top plate. 600lb coils are the standard coils that come on the unassembled kit.
basically the Procomp is the budget shock. the OME is a good all around shock and a step up from the Procomp. the Bilstein is a longer soft valved shock. it is longer than the OME or Procomp and requires at least a 3 inch lift
Old 08-04-2010, 12:22 AM #26
Steeze,
You're a lifesaver man. I'll be going with the unassembled kit to save a little cash since I can assemble & install it myself. I only have one more question... I plan on running LC coils (either 8 wraps or 7 wraps) in the rear with Bilsteins shocks. And my question is I've done some reading and from that I've gathered that the shocks sold by you guys at ToyTec are actually tacoma shocks(Rear Bilstein Shocks for 96-02 4RUN) while the ones that come with the SS kit (System 1.2 - Rear only lift - $695.00 : Sonoran Steel) are specifically made for the 4runner. There is nothing on either website that claims these things, I have just read them in various threads. So any clarification here?
Duhockey posted this in one of the threads I was reading... Are these the same shocks? Amazon.com: Bilstein BE5-6250-H5 5125 Series Gas Shock Absorber: Automotive
Old 08-04-2010, 12:41 AM #27
Moderator
Real Name: Dylan
Moderator
Real Name: Dylan
i'm not sure what shock SS uses but the ones that ToyTec sells are the 6252 shock. Bilstein doesn't really make the shocks specifically for a certain vehicle with the 5125. they just have a list of different shocks that are different length/travel and valving. here is the part list. Bilstein
we made a eye to stud adapter for the shock so it would work on the 4runner and it also gives it another flex joint at the top of the shock. I have those 5125's on my 4runner with the 8.5 wrap LC and i love them. they ride great and have a ton of flex
Steeze,
Old 08-23-2010, 04:30 PM #28
mdgrmt mdgrmt is offline
mdgrmt is an unknown quantity at this point
My Lift
I installed a 2.5 inch lift kit from fat Bob's Garage before my Uwharrie trip.
Photobucket
Mdgrmt's 2002 4runner
Modifications: OME 890's, toytec front coil spacers (2.5"), new upper ball joints, Rhino Lined Mirrors, Rhino Lined grille, remove runners, Goodyear Duratrac 265/70/R16, led interior dome lights, LED light bar
mdgrmt is offline   Reply With QuoteReply With Quote
Old 08-29-2010, 09:42 PM #29
Izanewman's Avatar
Izanewman Izanewman is offline
Izanewman is on a distinguished road
Izanewman's Avatar
Thanks for this information! I just got my first 4runner(99', manual, v6, SR5) at the end of last year and I'm ready to put some money into it.
I'm considering a lift, 75% for looks and 25% for offroading. I work in highway construction and drive through highway construction projects regularly. I've had mine nearly hung up a few times and it always worries me. Still, I need a good daily driver as I travel 25 miles to and from work plus trips to sites.
Question about the spacers if anyone can help. As far as reducing the life of the spring, can anyone estimate how much life is lost? Also, mine is a 99 model with original springs. Currently there is no sag, but wouldn't the effect of the spacer be worse on old springs like mine?
I've researched the OME 2-2.5"set up. What I have read has me very interested. I'd like to retain ride quality as much as possible. Any idea what a reasonable price to install would be? I'm not set up to try and do it at home. Plus, I'd probably screw something up.
With the OME 2-2.5", what would be a good tire size selection to match. I'm leaning towards BFG AT or a Goodyear Duratrac.
Izanewman is offline   Reply With QuoteReply With Quote
Old 08-29-2010, 11:19 PM #30
brian2sun's Avatar
brian2sun brian2sun is offline
brian2sun has a spectacular aura about brian2sun has a spectacular aura about
brian2sun's Avatar
Spacers suck. I had some on mine a for less than 2 years and they finished off my already tired coils. The ride sucks and only gets worse, but if you're limited on $$ and want it right now, it's a cheap lift. If you don't want to pay to do it all over again in a year or 2 and save money in the long run, get the OME Complete Package or the Toytec Ultimate lift and do it right the first time. Talk to Dylan (steezemcqueen) at toyteclifts.com and he can get you set up.
It takes about 4-8 hours to install a lift the 1st time yourself, I would expect a shop to charge you $3-400. My advice... do it yourself at a buddy's house. All you need is basic tools and you will gain some valuable knowledge about how your truck works too.
You can run 285/75/16s (33x11s), 255/85/16s (33.5x9.5), or 265/75/16s (32x10) with the OME 3" lift. If you get 881s w/o any spacers and 906s (OME 2" lift), then the 265/75s would be the better choice IMO. The 285s and 255s look better with the bigger lift, but the 265s are a little cheaper so that's your call.
1997 4Runner 4x4 SR5 - Geared, Locked & Armored
**CLICK FOR '97 BUILD THREAD**
2021 Tacoma 4x4 TRD Off Road Double Cab Short Bed (my DD)
2017 4Runner 4x4 Limited (the wife’s)
brian2sun is offline   Reply With QuoteReply With Quote
Ultimate Lift Thread Information Portal kregg 3rd gen T4Rs 9 09-23-2020 12:21 AM
Buying a 95 4runner, need information to customize Buggerout Classic T4Rs 7 05-13-2012 12:36 AM
03 4runner, multi information display captain204mike 4th Gen T4Rs 3 11-08-2008 02:34 AM
All this information! swisstype 4th Gen T4Rs 8 12-31-2007 12:58 PM
2003-Up Toyota 4Runner (4th Generation) Information Thai 4th Gen T4Rs 6 04-28-2006 08:17 PM
