08-18-2013, 08:54 PM
#361
Originally Posted by Brian757
Did someone already cover the Eibachs provided on the Toyteclifts.com website?
I am wondering about those as well.
I'm running them now on Taco 5100's and am really happy with the ride and stance.
1996 SR5 4Runner - TRD Supercharger, E-Locker w/ Blue Wire mod, Taco Billie 5100's, ToyTec 3" front coils, OME 890's, ToyTec Diff Drop, 285 Terra Grapplers on FJ Cruiser wheels
1985 SR5 Xtra Cab - 5.5" AOR/Alcan springs, AOR greasable shackles, 5.29's, Lock-Rite out back, Hi-Steer, Marlin Crawler dual case w/ Turtle Tuff skid/crossmember - SOLD
08-18-2013, 08:58 PM
#362
Probably been asked 1000's of times but I can't find a clear answer regarding the common 2.5inch Front and Back spacer lift.
Would in need to also buy 2.5inch shocks to accommodate for the added ride height?
08-30-2013, 11:06 AM
#363
Real Name: E
Real Name: E
Before / After - Stock / Tundra-OME
Here is a before after of my Tundra TRD front coil with stock Bilstein shock and the OME 890 in the rear. The photo does not show a whole lot of lift because of the running boards and the angle...But the OME gave me a full 2" over the 99 coil and tundra front gave me a full 1 1/2". The ride in the rear is fantastic and the coil is real long so when the truck articulates it does not let the coil unseat at all...
Before - Stock
After - Tundra / OME 890
1999 Limited 4wd / Tundra TRD front coils-OME 890 rear / Yak Rak / Green / Good Year MT / t4r.org /
09-01-2013, 05:51 PM
#364
Real Name: E
Real Name: E
center of hub to fender specs
many posts were deleted for some reason but to repost the info for those who were asking, the front of truck does not have the adjustable bilstein 5100's that will give me about an inch more lift up front. It has the stock bilstein tundra shocks. So, after that I assume a more level, lifted ride. Right now, the front and back are as follows.
Center of hub to fender.
Front - 22.00"
Back - 23 7/8"
Reason: mis type of #
09-01-2013, 07:17 PM
#365
What rear shock are you using?
09-02-2013, 10:10 AM
#366
Real Name: Sully
Real Name: Sully
I have tundra 5100 for front and rear with OME 883s for front and 890s for the rear does anyone know what the perch heights are on there?
09-04-2013, 11:16 PM
#367
Real Name: E
Real Name: E
I am just using the stock 4runner shock...It is real soft..I am looking forward to the 5100's...So, stock 4runner in back and stock Tundra TRD Bilstein yellow and blue in front...
09-08-2013, 10:58 PM
#368
Originally Posted by Elton H
since 05 has been too busy i thought id throw this up for him also noitce how they changed the emblems i like the old style better
How Much Of A Lift Is On This? ANd What Tires? Do You Have A Side View?
09-09-2013, 11:14 AM
#369
Real Name: Isaac
Real Name: Isaac
@ steezemcqueen
hey can we put stock hub to fender height in the first post so guys have a rough bassis and idea of where they sit, like how much sag they have now with 280k miles, or how much lift they already have -say they bought it used already lifted and dont know anything about the lift. i know for me i also keep forgetting stock height so its hard for me when im playing around with my front lift and setting things back up or running different settings on my 5100s and different spring combos or trim spacers or top hat spacers ect. it would be nice to have a base line to go from at a common/centrally located place and i think the lift thread is that place...
if a*sholes could fly this place would be an airport -2004 GX470 spm -97 SR5 3.4, SCS Stealth 6's w/305 70 17s MTRs, Icon 2.5" RR w/700#coils, OME861s w/Icon tacoma 2.0 RR, ARBs w/nitro 4.88, PIAA LED lights, 170amp CS144, ARB snorkel, ARB bumper w/xd9000ce, CBI swingout loaded, BudBuilt skids, lil skip tank skid, sliders, LCE 231s(d&s), first gen roll bar mod, LED interior/dash lighting, B&M 70624+perma cool w/electric fan, dual electric fanshttp://www.toyota-4runner.org/3rd-ge...ld-thread.html
http://www.metaltech4x4.com/
09-09-2013, 11:46 AM
#370
Moderator
Real Name: Dylan
Moderator
Real Name: Dylan
Originally Posted by the kid
@ steezemcqueen
Good idea!
Its hard to say exact since there are a different height stock springs (99 talls vs 01-02) and the stock springs will probably have some sag by now. But a good baseline is that most 3rd gens should measure 20 inches from the center of the hub up to the fender in the front and about 20.5 in the rear. I will add that to the OP.
The Rock Turtle Lifted, Locked, Boosted, Armored, TacoBoxed, and awaiting destruction.
09-16-2013, 01:03 PM
#371
Hi I just bought some treadwright 265/75/16 guard dogs (buy 4 get 5th free) and found they are a little larger than my 265/75/16 duratracs - probably around 1". What will I need to do to fit the tires on my stock 2002 4runner? I bought the tires to save money but now looks like I will have to spend more unless I cut the fenders?
BTW, I had terrible experiences with goodyear duratracs with flat tires from gravel from day one. I had to replace all but one so all the tires were mismatched - which caused difficulty disengaging from 4x4 unless I put it in reverse. With the center diff locked, even reverse sometimes wasn't enough to disengage.
**edit** Just returned from having them installed. Some plastic on the front right lower rear of the wheel-well needed some trimming. I hope that's it but probably not since the other side looks like there's only a millimeter of space in the same area.
09-21-2013, 04:21 PM
#372
I just bought a used 2001 4runner limited with a about 140k miles and i wanted to go with the trd lift, but i'm having trouble on figuring out exactly what parts i need for the lift. I want to lift it about 3'' and im trying to avoid paying out the nose for it. Ive found two front coils and shocks for a tundra trd in texas for about 50$ but they are for the 2wd, will they work?
09-23-2013, 06:23 PM
#373
09-23-2013, 08:51 PM
#374
Moderator
Real Name: Dylan
Moderator
Real Name: Dylan
Yep thats Procrap..er i mean Procomp for ya.
10-07-2013, 10:18 PM
#375
@ 99yota4
@ brian2sun
@ ChildrenOfBodom
@ Duhockey
@ kregg
@ steezemcqueen
@ xskydivingdudex
any way we can add the measurements of factory vehicles? after all this time playing around with my lift i dont know how mine sits from the factory anymore.
Never ask a girl if shes sick, she might not be wearing any make up. - lets just say she went storming off.
Never tell your wife she looks tired, they tend to hit and say that means she looks ugly. (weird logic i know)
