Front options are:
- 880 1" lift coil for stock weight.
- 881 2.5" lift coil for stock weight.
- 883 3" lift coil designed for 100 lbs. additional front weight.
- 882 3" lift coil designed for 150+ lbs additional front weight.
- A top plate spacer can be combined with the 881 coil for a full 3" lift
for the rear you can choose from:
- 906 2" lift coil
- 890 3" lift coil
- 891 3" lift coil designed for additional weight.
Pros: Provides a decent amount of lift, gives a quality ride.
Cons: Not adjustable, more expensive than spacers. can sag over time.
[/QUOTE]
So whats the most reputable source for purchasing the 891 3" lift coils for the rear? I'm looking around online and haven't found a decent source yet. also am considering replacing the rear shocks while I'm doing the springs. Whats a good shock match for the 891 springs? usually have about 100-200lb daily and more for trips.[/QUOTE]
1st time ordering a lift so right or wrong I ordered OME890's and 5100's from Wheelers during the there Black Fri sale I have not received yet so have no experience other than what I have read and talking with Wheelers and what I wanted to accomplish. 2.0" lift and 100lbs normal and maybe 300-400lbs on weekends without going over sprung and riding like a truck LOL
I believe the table you provided for the front shocks may have the info for the 882 and 883 reversed if you look at the numerical progression? I order 5100's and 883 for the front with a 200lb winch bumper combo.
OME-964R - Old Man Emu Rear Coils (96-02 4Runner)
Designed for superior performance across all terrain, an Old Man Emu suspension upgrade by ARB will provide noticeable improvements to a vehicle’s performance, including load carrying capacity and control characteristics.
(2) OME Coils, select from dropdown:
906 - Approximately 2" Lift - Medium Load - Stock Weight
890 - Approximately 2-2.5" Lift - Heavy Load (330 lbs -GVW)
891 - Approximately 2-2.5" Lift - Heavy Load (Constant 660 Lbs -GVW)
