06-29-2021, 09:45 PM
#901
That's not the skid plate you are looking at! I have removed it for now. There are these 2 bars that drop the steering rack and the lower control arms I guess.
after some wire brushing lol, I found a label on the shocks! Reflex p126 71352L
I wonder if I could just ditch the massive spacer and replace it with bigger shocks/coils?
06-29-2021, 11:33 PM
#902
Real Name: Devan
Real Name: Devan
Man you're throwing some curveballs here Interesting as hell nonetheless
I most certainly would, and would start undoing all this mumbo jumbo too. I have no clue how it feels now but I bet you'll find it rides much better
There's plenty of information in this thread as to what's available, what's needed with a lift, doing it on a budget, etc. as I'm sure you've seen. My advice is most things you see that are "recommended" you'll probably find are necessary, so keep that in mind. That just seems to be the case with many, myself included
06-29-2021, 11:44 PM
#903
It actually drives quite nicely.
When I got my wheel alignment after a new steering rack, they told me it was a weird lift, but solid so I should probably leave it .
Do you guys see any problem with just taking out the massive spacer and replacing the shock/coil with something that will give me the same lift and allow me to add the winch and plate bumper?
06-30-2021, 12:25 AM
#904
4” procomp lift
06-30-2021, 10:31 AM
#905
Real Name: Patrick
Real Name: Patrick
Hello, long time lurker here I'm in the middle of welding up a coastal offroad bumper, and can't for the life of me figure out what kind of lift I have. From centre of hub to limited fender I have 25" front and back.
The rear looks to be a bigger coil and shock but what the hell is on my front!? Obvs this was installed by previous owner. The only marking I found was on the skid plate. Just tells me it's made by pro-comp.
I will be putting a winch on this as well, and wonder If I need to change things up to avoid sagging.
Thanks in advance!
Someone put a 4" procomp lift meant for a tacoma on your 4Runner in the front and then probably used coil spring spacers in the rear. In order to install that they had to cut and weld so now you are pretty much stuck with it unless you swap frames or cut and weld what you need from a donor frame.
06-30-2021, 12:01 PM
#906
Hey all! I'm planning on installing the Sonoran Steel 1.2 lift kit on my 2001 4Runner, and I was wondering what kind of tire size this would allow me to run? I see 285s seem to be pretty popular, but I'm new to the 4Runner world, so I'm not as well versed. Thanks!
07-11-2021, 04:13 PM
#907
Real Name: Devan
Real Name: Devan
Oddball question, but does anyone have pictures comparing Tundra TRDs/5100s to Tundra Eibachs/5100s?
09-20-2021, 08:25 PM
#908
Originally Posted by 96RedRunner
Had SS1.2 Billy 5100's Tundra/LC 8 wrap on 96Red long time liked it.
Red's 01 replacement tried OME 3" lift, had to go.
Giving the Billy 6112 & 5160 setup a try 6k mi on it, seems to be a step up from 5100's.
I sent you a pm, but curious how you are liking this combo
2000 Sport - 4x4, e-locker, 17" FN Konig Countersteer Type X's, 285/70r17 Toyo AT3s ...
10-06-2021, 09:35 PM
#909
Hey guys,
I am looking to put a 3 inch lift on my 01 sr5 4wd. What is the best set up to run?
10-07-2021, 10:58 AM
#910
Real Name: Patrick
Real Name: Patrick
Originally Posted by jcmb45678
Hey guys,
How much money you got?
10-07-2021, 11:41 AM
#911
The goal is to keep it under a grand
10-07-2021, 11:45 AM
#912
feel like at that price it's OME shocks and coils vs OME coils on Bilstein shocks. Also stiffness and shocks depend on use of vehicle. Road, Offroad, combo, etc.
99 Limited: 4wd conversion, OME 883/891, Built Right UCAs, Armored and winch up front, 285's with 4.88s and dual locked.
10-07-2021, 12:28 PM
#913
Real Name: Patrick
Real Name: Patrick
Have you replaced the lower ball joints or know when they were replaced? I know it seems like we're beating a dead horse about lower ball joints, but they will cause a lot of damage when they fail. OEM only unless you know how to check them properly according to the FSM or feel like replacing them often.
For under a grand bilsteins with OME springs is pretty popular. You might also look at toytec's bilstein lift kit too: BK9602 - 3" lift Toytec/Bilstein kit for 96-02 4Runner
10-07-2021, 01:40 PM
#914
What about this setup? using OME 881 for front and OME 890 in the back
10-07-2021, 02:41 PM
#915
Real Name: Patrick
Real Name: Patrick
That's a pretty popular setup as well. I'd recommend adding the extended brake lines for the rear. (2001-2002 require 2 extended brake lines for the rear vs 1996-2000 only require one.)
