Thread Tools Rating: Thread Rating: 53 votes, 4.85 average. Display Modes
Old 05-08-2024, 02:02 AM #1126
96RedRunner's Avatar
Real Name: Mark
Real Name: Mark
Originally Posted by Mendoncyclesmith View Post
96 SR5. 2" OME suspension lift, all the way around. Wanted to correct tire/body clearance imbalance, as the front sat lower than the rear. Went to some folks who I shouldn't have, and ended up with a 2.5" lift block on my struts, and suddenly, "Carolina Squat". Got it sorted by lifting the rear with blocks, but now it's wicked tall, and not in a way that is truly improving off road capabilities
4.5" lift way you've done it going to cause you problems as described on a 3rd Gen.
One of your posts you mentioned receiving a package with offending packaging tape labels on it.
Reap what you sew Bro, Karma.
96RedRunner limited 4x4 5VZ auto not stock 374k miles totaled 2018.
2001 limited 4x4 5VZ auto work in progress.
2011 Audi S5 Prestige 4.2 V8 6 spd MT.
Old 05-09-2024, 02:12 PM #1127
Mendoncyclesmith Mendoncyclesmith is offline
Mendoncyclesmith is on a distinguished road
Ha! Thanks, appreciate it, as long as I'm on the right track, my sanity can reassert itself.
Sadly, these issues existing pre-proselytizing packing materials, so Jesus didn't cause this problem....
That said those UCA's are great, and definitely helped with getting my 34's to not rub, so win, there.
Mendoncyclesmith is offline   Reply With QuoteReply With Quote
Old 05-10-2024, 02:45 AM #1128
Endlessblockades's Avatar
Real Name: Blair
Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold
Real Name: Blair
What is meant by 'front axle sliding'?
Old 05-11-2024, 09:31 AM #1129
Real Name: Mark
Real Name: Mark
Didn't say you are on the right track, cause and effect.
Sanity restoration ditch spacers and go with body lift. History repeats itself.
Auto correct Sew - Sow
Old 05-14-2024, 12:47 PM #1130
I honestly don't know, I'm not a vehicle mechanic.
Had a brief conversation with The 4x4 Center in VT, and they did mention using extended axles in certain situations, so I'm working under the belief that this was what my mechanic alluded to.
'96, ah, got it. Since I'm in the thread about this? I keep reading contradictory info regarding the best type(s) of lifting for actual use off road.
Sounds like you advocate for body lift over suspension or spacer blocks?
Old 05-14-2024, 01:43 PM #1131
(Suspension) Spacer blocks are almost always a bad idea for performance, especially off road. Small body lifts are generally ok and help with tire clearance, especially for independent suspensions.
Your goal is to find the right compromise of clearance (tires, approach/departure angles, etc.), wheel travel (both up and down) and price for your situation. Different shocks will also perform better or worse in various operating conditions (high/low speed, etc.).
There is no one right answer.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 05-14-2024, 01:52 PM #1132
Real Name: Blair
Real Name: Blair
Hmmm OK. We have 2 front axles and that just struck an odd note.
I don't think you meant the second part of your reply for me, but I'll add that I like to keep a lower center of gravity and consider myself a 4X4 lowrider (basic 2/2.5" Bilstein 5100 with 881 front and 906 rear springs - no body or spacer lift activities). These vehicles are super-capable and do what I need although I probably push it too far from time to time. I do have a pair of the Trackmotive extendo axles ready to install because even a mild lift will destroy your OEM CV boots in time.
Ultimate Lift Thread Information Portal kregg 3rd gen T4Rs 9 09-23-2020 12:21 AM
Buying a 95 4runner, need information to customize Buggerout Classic T4Rs 7 05-13-2012 12:36 AM
03 4runner, multi information display captain204mike 4th Gen T4Rs 3 11-08-2008 02:34 AM
All this information! swisstype 4th Gen T4Rs 8 12-31-2007 12:58 PM
2003-Up Toyota 4Runner (4th Generation) Information Thai 4th Gen T4Rs 6 04-28-2006 08:17 PM
