10-09-2019, 12:12 PM
#526
Real Name: Patrick
Real Name: Patrick
Originally Posted by nwguy
Awesome, thank you for passing that along, I will look into that once I have a press in my shed. Do you still have the tool? What's your ETA for being completed with it?
I've still got it, and I'm all done. It's all packed up and ready to be sent to the next person. I included a 4"x4" square steel piece and a couple pvc pieces I bought just for this job.
10-11-2019, 04:11 PM
#527
Was asking around here in Birmingham, for labor, I'm being quoted $280 for disassembling & reassembling both rear axles. Does that sound like a fair price?
1997 4Runner SR5
10-11-2019, 10:11 PM
#528
One of my rear axle snap rings is lose around the axle....if it snaps in place and just isn't snug is it still good to use or does it need to be dead on tight and not be able to spin around the shaft with your hand. There is no slack....it doesn't rattle around it's not tight lol
Idk if that makes sense
Sent from my Pixel 2 XL using Tapatalk
10-12-2019, 11:47 AM
#529
Real Name: Patrick
Real Name: Patrick
Sounds like a fair price to me assuming your are getting both rear axle wheel bearings done, they are pressing off abs ring (if equipped) and retainers, and flipping the outer retainer during install for best seal with the redesigned axle seals.
10-12-2019, 12:50 PM
#530
While flipping the retainer is a good idea, it really doesn't have any actual benefit besides possibly giving you more room to work with. You still need to do a witness mark and ensure the seal is riding correctly.
10-12-2019, 12:52 PM
#531
Real Name: Patrick
Real Name: Patrick
That's correct. I chose to flip the retainer in order to center the witness mark while maintaining the same clearance between retainer and axle housing prior to retainer flip. I didn't want to place the retainer any further inboard than necessary.
10-13-2019, 02:27 AM
#532
I wish shops around seattle charged 280 for the labor. I figure the HF press is 144 right now and the SST is $110. Can't go wrong buying both even if it was just for one job.
10-13-2019, 12:18 PM
#533
When I did my bearings CarQuest charged $40 each axle to press on and off. Call around for a better deal.
2007 4Runner Sport 4WD 4.0L 228,000 miles
The real stats on gun murders in America compared to the world (link)
Good riddance to the Clinton Crime Family--> I Voted TRUMP…how’s it going for you now Trump is gone? Be careful what you ask for. You may just get it.
06-06-2020, 01:19 AM
#534
I was just about to refresh suspension and bushings on my daily driver at 210,000 miles and noticed my rear axle is leaking on the driver’s side.
Dealership wants $1,400 for a bearing, seal, and new shoes on the driver side only! My mechanic says he can’t do it. Backing plates are toast from rust, breaks should probably be redone, parking break is seized, but the axle housing is salvageable. I dont have the space to try it myself
Would it make more sense to look for a rear axle assembly in good shape and hope the bearings are good and replace the seals?
08-23-2020, 10:49 PM
#535
I think i just changed the worse' Bearing ever..the axle was wobbling almost 1/4inch Guts were Flying..
Hot Rodder Car Nutt- Enthusiast for over 35 years! Biker -Builder ..Amateur GunSmith-Amateur Explosives Expert-Expert P%ssy LicQer ... E-Lock Grey Wire Mod. Rough Cunt' 3'Lift' Dick Cepek DC2s- 16x8' -12 offset" 285 75 16' IRONMAN MUD COUNTRY's ' ,On-Board Air,"EngineStand Tire Carrier" 12,000lb'winch'-DualBatterys
08-25-2020, 02:02 PM
#537
part pictures for schematic organization
left is older, right is newer
10-23-2020, 03:30 PM
#538
Real Name: Antonio Claudio Michael
A 4runner enthusiastic made a special installer and removal tool for the axle shafts his name is Donald-the-bonald on eBay he is located in Omaha Nebraska and the tool says MCSpecial Inc on it 135 bucks for complete tool and the Tacoma adapter for second and 3rd gen models is an extra 45 bucks if anybody needs the links let me know
10-29-2020, 10:33 PM
#539
yup just both of mine today. His kit comes with a press sleeve with a window so you can measure your 4-5mm polished axle spacing. Made the job very easy, well worth the $120 or so bucks. I was an idiot and forgot about Timmy the Toolman's second video where he shows the new tool. I was following with the first video and wasn't paying attention, crammed the first one one over an inch in!!! and of course the tool was too wide to press out the tone ring and retainer at that point, so I had to cut them off super carefully and buy new ones at the stealership. dumb mistake costs me 137 bucks.
10-29-2020, 10:57 PM
#540
also just a tidbit on the 01-02 axle bearings vs earlier generations...when I did mine today, they literally just went in with a little tap of the hand. you don't even need the press for the bearing, and even if you do press it in, when you put it on the axle for the retainer pressing, the bearing will just slide right out onto the axle shaft. not a huge deal, it's just a little awkward carrying it to the press while the brake wheel jiggles around between the bearing stuck point on the axle and the axle flange.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
