Originally Posted by DWilliam
2002 sR5. Taking truck to mechanic to do injectors. Midwest is $350 for the set, any other options?
What else should I have him do while he’s in there? Valve gasket? I’d appreciate part numbers too if available, just to make sure I get the right stuff. Thanks!
Yes, this would be a good time to knock out your valve cover gaskets, spark plug tube seals, etc. etc. If you type into T4R or Google you'll find a ton of info on the job. Timmy the Toolman is an excellent resource to refer to all 3rd gen related things.
mtbtim
might also have some input on injectors. There was a company I think he used but it wasn't that one. I can't recall. Hopefully he can chime in.
