Originally Posted by Skybill
Great information.
I have a question; what size are the Tundra rotors?
The reason I ask is that according to the build sheet, my 1998 4Runner came with 13" rotors.
I believe on the V6 4runner and 199m Tundras, the rotors are 12.5", but Tundra's are wider and require a wider caliper.
231, though, are even larger.
Whatever... here's the 4Runner brakes from a base model with 15" rims vs 231 big boy brakes
Originally Posted by MTL_4runner
Here is a shot of the rotors side by side anyway:
4Runner or Taco
Tundra
For reference, the inside hub portion is the same size on both.
There may a slight bit more surface area for braking on the Tundra version (this would be fantastic for towing).
I do also believe they are thicker as well which would resist heat warping that much better.
