Old 11-19-2013, 10:41 AM #31
J.A.'s Avatar
J.A. J.A. is offline
J.A. will become famous soon enough J.A. will become famous soon enough
J.A.'s Avatar
Toyota 4Runner Highlander Throttle Body cleaning and O Gasket Mod
Toyota 4Runner Highlander Mass Air Flow Sensor MAF cleaning
J.A. is offline   Reply With QuoteReply With Quote
Old 11-19-2013, 11:12 AM #32
hrt4me hrt4me is offline
hrt4me is on a distinguished road
thanks!
hrt4me is offline   Reply With QuoteReply With Quote
Old 11-09-2015, 12:09 PM #33
OldManKamps's Avatar
OldManKamps OldManKamps is offline
OldManKamps is on a distinguished road
This needs to be added to the FAQ/Guide sticky!
OldManKamps is offline   Reply With QuoteReply With Quote
Old 11-09-2015, 04:49 PM #34
Bstrom's Avatar
Bstrom Bstrom is offline
Bstrom is on a distinguished road
Bstrom's Avatar
Originally Posted by Elton H View Post
96-98 has different style maf sensor
I just cleaned my '99 MAF. It is just a little component between the airbox and resonator. Two screws and it pops out. Sprayed it with CRC brand cleaner and reassembled. The dealer had done it a while ago but now I know it's clean!
Bstrom of Powell, TN
2003 Tundra | 1999 4Runner Limited 4WD | 2011 Mazda CX-7 Sport
Bstrom is offline   Reply With QuoteReply With Quote
Old 11-10-2015, 06:31 PM #35
How did those screws come out for you? The guide said you would strip them no matter what so I'm a little apprehensive
Old 11-10-2015, 06:36 PM #36
AZBub's Avatar
AZBub AZBub is offline
Real Name: Chris
AZBub will become famous soon enough AZBub will become famous soon enough
AZBub's Avatar
Real Name: Chris
Cleaning MAF
I can't remove mine at all so I take the air box out and shove the MAF cleaner straw into the MAF and spray away. lots of dark crud came out the first time I did this.
the 2 screws were a PITA. one stripped out the other barely made it.
AzBub Build2000 Toyota 4Runner Highlander, 4x4, E Locker. 4:30 gears. TRD Taco springs on Tundra 5100s. FJ80 8 wraps/Monroe economy rear lift.
AZBub is offline   Reply With QuoteReply With Quote
Old 11-10-2015, 07:02 PM #37
No worries about damaging the MAF with overspraying it?
Old 11-10-2015, 08:17 PM #38
AZBub's Avatar
Real Name: Chris
AZBub's Avatar
Real Name: Chris
leaves no residue. haven't had a CEL since.
Old 09-02-2017, 09:13 AM #39
GTEE1997's Avatar
GTEE1997 GTEE1997 is offline
GTEE1997 is on a distinguished road
GTEE1997's Avatar
I HIGHLY recommend the procedure linked above for cleaning the MAF. Dismounting the air filter box so you can rotate on its side for direct access to the MAF screws is worth the minute it takes to do so. Unfortunately I began trying to remove the screws with the filter box in place using a stubby screwdriver and started stripping out the screw head before I realized how I should be working on it.
TWO RECOMMENDATIONS:
1) Use a adjustable torque drill/screwdriver to break the screws loose. I started with the lowest torque setting and stepped it up after a few seconds counter rotation was applied. I was able to get out the screw that had started to strip, think the ratcheting impulse force from the drill helped free it from being locked in placed. THIS WILL WORK BETTER THAN A HANDHELD SCREWDRIVER!!!
2) You don't need to disconnect the electrical connector from the MAF! Just leave it attached to the wiring harness and clean it under the hood with a towel underneath the sensor. I was struggling to extract the electrical connector and realized that was unnecessary.
Cleaning MAF-drill-png
Currently Own: 2001 4Runner SR5 4WD, 2015 VW Jetta SE TSI, 2013 Chevy Volt
Why I bought it: http://www.toyota-4runner.org/2190029-post764.html
Last edited by GTEE1997; 09-26-2017 at 04:02 PM. Reason: better order for the steps
GTEE1997 is offline   Reply With QuoteReply With Quote
Old 07-04-2020, 08:50 PM #40
Traveler74 Traveler74 is offline
Traveler74 is on a distinguished road
Originally Posted by kzak View Post
I cleaned my MAF sensor today and just wanted to add a photo to this thread that shows the actual sensor. It looks like 2 tiny resistors.
Yes, that is what my MAF looks like on my 1996 T4R. I was a bit surprised because I was expecting to see one with 2 little wires with bulbs on the end OR one with a screen type. Used CRC MAF cleaner and sprayed the heck out of it.
Traveler74 is offline   Reply With QuoteReply With Quote
Old 07-04-2020, 10:07 PM #41
TheDurk's Avatar
TheDurk TheDurk is offline
TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light
TheDurk's Avatar
Those screws, like all Phillips head screws on Toyota cars and trucks, are JIS standard. You need a JIS screwdriver or THEY WILL STRIP every time if at all tight. An American SAE Phillips driver will cam out so they strip.
JIS (Japanese Industrial Standard)
This should be part of ANY DIY on cleaning the MAF. If no one has boogered them previously, they come out just fine with a JIS. I highly recommend the Vessel brand drivers. Even if stripped by an SAE driver, the JIS tool goes in deeper (that's what she said) and often can remove what is thought to be a screw stripped beyond repair.
My Backyard Frame Swap
