06-24-2011, 01:00 PM
#16
I just did a tune up on my 4runner and now its making the clicking sound when i speed up. I gaped the plugs @ .32
08-14-2011, 11:37 AM
#17
I'm having this exact issue with mine. Can anyone be a little more specific with where I should be looking?
Thanks,
Alex
08-14-2011, 01:06 PM
#18
Originally Posted by 99yota4
How hard is it to replace spark plugs and wires? I've been wanting to do that. I apologize for the newb question but where is the coil pack and what does it do?
Instructions for changing spark plugs here, indexed with a bunch of other useful stuff:
3rd Gen Tutorial & Documentation
Pics of coil packs included.
2012 4Runner Limited, Shoreline Blue Pearl / Beige leather, RCI skid, ext rear diff breather, Derale 13504 cooler, 110K
1993 300ZX Cherry Red Pearl with some bling, K&N intake, PowerTrix suspension, 130K
09-12-2021, 02:06 AM
#19
Clunking or knocking sound only when accelerating
Hi. I'm new here and i have this problem with my 3rd Gen 4runner. Whenever i am accelerating within 40mph i hear a clunking or knocking sound on the passenger side after i have replaced my cv axles and repaired and replaced the ujoints in my drive shafts. The clunking sounds only shows when i am in gear and only when i am accelerating from 0-40mps. Tried putting gas on neutral but there was no clunking sound. I hope somebody could help me with this.
09-13-2021, 01:35 AM
#20
Real Name: Jacob
Real Name: Jacob
Check your U joints, that's what I would do.
Sent from my SM-G986U using Tapatalk
01-18-2022, 12:56 PM
#21
Real Name: Brad
Real Name: Brad
Ticking Solenoid on Charcoal Canister
Hey Guys,
I have a ticking on the solenoid on my charcoal canister. I can grab it and the ticking will not be as prominent. I was thinking about making a Stainless shroud for it and covering with Dynamat to reduce the sound.
Has anyone had a fix for the solenoid ticking? I have no codes and it runs great. But it sounds like a 22re that needs a valve adjustment. It goes away on decel but at idle it is very loud.
2000 SR5 Sport 4WD, A/T, E-Locker, 285k, no lift, 265/75/16'S
Mods- ISR, Deckplate, Ultra Gauge, Spiker Mount
Gave up on making it nice.
SAS coming up
FJB
01-18-2022, 01:12 PM
#22
Originally Posted by MTRunner00
Hey Guys,
It's normal, it's called the Toyota tick. Mine clicks as well Ivé gotten used to it.
01-18-2022, 02:34 PM
#23
Real Name: Brad
Real Name: Brad
I understand that its normal. I still am tired of hearing it and want to reduce the sound.
SAS coming up
FJB
01-18-2022, 04:01 PM
#24
Good luck.
01-19-2022, 01:07 AM
#25
Go find an old straight piped tractor or a cab over semi without power steering and go spend a day in it. You won’t care about a tick in your Toyota after that.
99’ Black “Highlander” sport, oak, 5VZ auto, 4.30 axle, e-lock, 265/75 Grabber X3,, Bilstein 6112 (2”) front 5160 rear shocks, OME 2906 springs, Durobumps, 4x Inovations front middle rear skid plates, 4XI square TRD tube sliders, lil skips tank skid, lotus dev RCA skids, overland custom sway bar links, Amp’d hidden winch, warn Vr Evo 10s
