07-12-2010, 04:22 PM
Lifts Again
So I can not decide what kind of lift I want to get. I just want it for looks. Around 3 inches. I want a little bit meaner looking truck. It will not be going off road since it's a 2wd and I would rather break a 4 wheeler than a car. I was thinking about the Toytec $300 spacers with rear ome coils. I want to keep the ride quality as close as possible or better. I don't want to spend a ton but I do not want junk. I don't want a body lift either. Should I go with this? Is it everything I need to get it a little higher off the ground? I plan on keep the tires right now (265/70r/16) but I will get bigger ones later on.
07-12-2010, 04:37 PM
if you are not going to wheel it I would recommend just going 2.5" with a spacer lift, I think you are going to still want new shocks and struts though.
[FONT="Comic Sans MS"]Black '97 SR5
Mods: OME lift, 285's, 99 hl's & fr rr seats and some other stuff!!!
07-12-2010, 04:38 PM
If you want it to ride as close to how it does now, then a 2.5" Daystar spacer kit for ~$175 is probably your best bet. I love my OMEs, thet're wonderful off road with the tires aired down, but on road they ride noticeably stiffer than factory coils.
2021 Tacoma 4x4 TRD Off Road Double Cab Short Bed (my DD)
2017 4Runner 4x4 Limited (the wife’s)
07-12-2010, 04:44 PM
What would be a good place to order the 2.5 daystar spacers? Also what size tires would I be able to run after that? I'm not looking for huge, just a little bit of difference and a meaner look. Should I also get a dif drop for mine since it's a 2wd? I thought that they were only used for 4wd but after reading I found out different.
07-12-2010, 04:57 PM
This is about the cheapest you will find the whole kit (front and rear):
Daystar KT09106BK - Daystar Comfort Ride Polyurethane Coil Spacer Lifts - Overview - SummitRacing.com
It shows red, but the description says black. You don't have a front diff so no need to drop it. You were correct before - only 4wds need the diff drop. you could squezze on some 285/75/16s (33x11") or 255/85/16s (33.5x10")with a little bit of pounding and cutting on your fenders, otherwise 265/75/16s (32x10") will fit without cutting.
07-12-2010, 05:17 PM
Alright I went to summit but when I choose my model (check application) it says that itll only work for the 1996-1997 limited and mine is a 1998 limited. I don't know if they're any different though in suspension.
All '96-02 4runners take the same aftermarket suspension regardless of SR5, Limited, or 4x4/4x2.
07-12-2010, 05:21 PM
Alright sweet. Just making sure before I order it. Thanks
07-12-2010, 05:22 PM
I am glad brian chimed in, good advise brian! I would just get 265/75's, just my penny.
07-12-2010, 05:33 PM
Glad to help! The 265/75s won't give you a big drop in power or affect your MPGs like the 285s or 255s will either so that's a plus. I personally like the way 33s look with a lift better, but 265s still look good, especially M/Ts.
07-12-2010, 08:29 PM
Hey! why does everyone point people at Daystar for spacer lifts...
Skyjacker makes a nice spacer lift that comes with new rear shocks in your choice of gas or nitro...
I dont see Daystar throwing down new shocks with their kit?!?!
07-12-2010, 08:53 PM
we were waiting for you to give your input, now we know!! good thing you got here before he bought something, LOL!
07-12-2010, 09:25 PM
I personally don't recommend Skyjacker's products because of my own experience with them and their company in the past. But yeah, it's another option. I was thinking cheap as possible too. If you're gonna get shocks, get better ones than Skyjackers IMO. Even ProCrap is better.
07-13-2010, 12:13 AM
If I can get away with just spacers then I will do that. I can always get new shocks later anyway. (My truck would probably lift up some if I had new shocks. After 234k, I don't know if they have ever been replaced).
07-13-2010, 12:15 AM
Shocks don't lift. Only springs do that.
Check out my garage.
