07-26-2010, 04:56 AM
Rear Axle swap
Done my search but i'm missing the foundation of understanding this mod. I have a 4x4 3.4 auto without an e-locker and found one for sale. I am interested in making the move to purchase and hopefully swap this "complete rear axle" with the e-locker. What do I need to look for, can I perform this on my own or do I need a professional to do it at a shop? Are the stock 4.10 or 4.30 gears for the e-locker good enough for bigger tires (say a 35 inch tire) Any info or help would be greatly appreciated! Thanks
[99 T4R sr5 "highlander" 4wd][Deck plate mod][Clear corner/signals][Tundra/Sequoia Skid][Sound&Security upgrade][TRD Tundra/FJ80 LC coil lift][Tint][01-02 tail lights][14" Magnaflow]
Future mods***
[ISR mod][LED interior]
07-26-2010, 07:33 AM
First off check your truck to see if the dash is pre wired if it is you will need the factory switch and locker ecu . here are some helpful links if you are mechanical you should have no problem following this to do the job mine works great. I wold recommend going to 4.88 gears. mine with 33's and 4.10s is ok around town but out on the highway shifts in and out of OD. a lot and lacking the power for the hills. I have plans for 4.88 with 35's you might even want to go to 5.29s
Retrofit Electric Locker
Outdoor Recreation Network - Off-Highway, Jeep, & 4x4 Fun
Good luck and if you have a complete axle located jump on it fast.
2000 4RUNNER SR5 TRD Supercharger, OME 882's w/ topout's and n91sport strut up front.OME 851's w/ cones and trekmaster LC shocks in the rear. R.I. LED lighting, retrofit E locker, 1" diff drop, 315/75/16 cooper discoverer STT, 2" R.B. body lift, rear disc brake conversion, Ingen intake, Spectre cone filter, Fitch fuel cat, Cobra LTD29 CB, custom front, and rear bumper, smittybuilt 8000 # winch, 66" 4xinovations rock sliders w/kickout, lil skip's gas tank skid. Custom skid plates. My build thread is @ http://www.toyota-4runner.org/3rd-ge...ld-thread.html
07-26-2010, 12:37 PM
^ x2. I have 4.88s/33s and I would go with 5.29s for sure with 35s. Even with 4-5" of lift (suspension and body combined), you have to do a lot of cutting and pounding in the fenders to fit 35s and not rub off road in case your not aware.
2021 Tacoma 4x4 TRD Off Road Double Cab Short Bed (my DD)
2017 4Runner 4x4 Limited (the wife’s)
07-26-2010, 01:11 PM
So you guys are saying that I should snatch the axle, regear it to 5.29 and it will just swap right in? I'm not sure if the empty harness on the left side of the steering wheel is the E-locker harness. How can I confirm this.
Future mods***
07-26-2010, 02:01 PM
You do realize you'll have to regear the front diff as well right?
1996 SR5 4Runner V6 4WD Auto
Toytec Ultimate w/ OME 890's plus 1.5" daystar spacer
60028 OME shocks, Goodyear Duratracs 265/75 -16
B&M 70268 with Magnefine filter, 199mm TBU
236K miles
07-26-2010, 11:11 PM
To confirm your wiring arrangement look at pics and read the wiring section of this thread should help.
This is the thread I used to do my retro fit At least all the wiring part and yes the re geared rear-end will swap right in. As Brian2sun said keep in mind to that to fit 35's you will be doing cutting and hammering to your truck. I am running 3" lift with 2" body lift 16X8 wheels with 4" backspacing and 255X85X16 tiers or 33.5X9.5 and they rub some up front when flexed and turning.
07-27-2010, 06:28 AM
Real Name: Bryan
Real Name: Bryan
I wouldn't go with a taller gear than 4.88, personally...any higher and the pinion gets too small and can break alot easier.
You'll have to regear the front also to match the back.
You don't necessarily need the dash to be pre-wired, you can get a switch-to-diff harness from 12voltguy.com.
Millennium Silver 2001 4Runner SportR5lander
Photo Timeline - Solid Axle Club
All-Pro, Fox, Eibach, OME, Goodyear, Trail Gear, Yukon, Solo Fabworks, Marlin, TJM, Smittybilt, Front Range Offroad, Inchworm, Addco, Savage Offroad, B&M, Borla, Pioneer, Cobra
Northeast 4Runner Owners Association
07-27-2010, 12:48 PM
I say get them set up at a place that has a good 3-5 year warranty and enjoy the power you'll have to push 35s with 5.29s. I do agree with LINY that the lower the ratio, the weaker the pinion, but it's still not common for 5.29s to break. 5.71s and lower start having issues. If you're going to spend that much money, get the power you need. I would not be happy with 35s and my 4.88s - that would feel like a 4 banger.
