07-29-2010, 04:36 PM
New Radiator to avoid pink milkshake
I'm looking to do some maint. on my ride this week and with 150,000 miles and all the stories of the milkshakes, I'm getting worried. It's not very expensive for a new aftermarket radiator which I figure should last another 150,000 miles. I was going to go with a cooler but I have to drain the radiator to install the timing belt and new water pump so why not just replace the whole thing. Anyone see a 2 row radiator for the 4runner? I've seen ones just like the factory ones and I've seen steel ones that are 2 row. Why are only the steel tank ones 2 row? I was never a fan of the plastic tanks but so far they've held up. Anyone have any insight on this?
Thanks!
07-29-2010, 04:41 PM
I remember coming across some two row plastic tank ones a while back when doing my research but can't remember where. I am also looking at replacing my radiator as well. the plastic tanks will sometimes develop a leak along the gasket where they meet up with the core but usually not a big problem. I would still go with a cooler since you will still need to drain ATF to change out radiator.
99 SR5 V6 4WD- just started
SOLD1998 T4R SR5 All-Pro CO's, UCA's and Sliders, SS 1.2 rear only DIY rear bumper, Aussie Locker and 1st gen roll bar mod. Outdoor Logic Front bumper, roof rack and Vision X lights.
07-29-2010, 04:59 PM
id rather spend the money on a real tranny cooler
98 4runner sr5 3.4L 5spd 4x4 e-locker sold 10/2/11
07 tundra 5.7L 4x4 limited dc was my moms r.i.p 3/19/11
Oregon Toyota Owners Club
07-30-2010, 12:11 AM
Real Name: Uhhh this is my real name
go with a Koyo
A1998 model online about $120 or so shipped. Fit my friends 01 Limited perfectly.
06 4th gen V8 4WD of course...
08 Honda Ridgeline RT
05 Scion xB-the toaster-daily driver
my Yota Fanatic photos are on Facebook- here is link:
http://www.facebook.com/album.php?ai...5&l=5795132731
07-30-2010, 03:23 AM
I just put a Koyo in a couple of days ago. I talked to an experienced transmission guy who runs his own shop-- he strongly discourages bypassing the stock tranny cooler in the radiator.
Side Note: I'm running 10-15 degrees hotter w/ new radiator, cap, thermostat and hoses, as read by a scan gauge. I'm still in the normal temp range, but I'd like to drop it back down-- I'm still troubleshooting it.
02 4x4 4runner - premature restoration in progress
06 4x4 Taco
07-30-2010, 07:39 AM
So, what the coolant temperature do you read on your SG now?
My scan gauge shows 200 - 207 range at 85-90 deg outside.
07-30-2010, 10:16 AM
2 row or koyo
I understand the koyo a1998 is the best aftermarket one out there but isn't it still a 1 row just like the factory?
The 2 row from advance auto I'm not sure about. Haven't heard of that company before.
Anyone ever find a radiator that is the stock size but doesn't have the trans cooler in it? I think that's the ideal way to go. Then get a sep. tranny cooler and it's the best of both worlds!
07-30-2010, 10:43 AM
What was his reason?
07-30-2010, 10:45 AM
At those temps, mine runs 180-190 on level ground and highway speeds with just water in the rad.
Going up hills and stop and go will yield temps 190-210.
07-30-2010, 10:55 AM
Real Name: Jeff
Real Name: Jeff
Ya , leave us hanging or what LOL . What was his reason for saying that ?
I've spoken with two rad shops out here after reading about this issue and both have never had a 4Runner pink milkshake vehicle come in , yet .
Do any of you think it could be your local water prematurely corroding the rads out ? Is this happening all over or just in some parts of the country ?
Thanks
1998 4Runner 4WD Ltd
07-30-2010, 11:07 AM
A lot of transmission techs will discourage bypassing the internal trans cooler for heat issues. In the winter your temps can be too cold. Cold temperatures are hard on the transmission and pumps as well. The guys I know recommend external coolers still attached into the internal cooler. I am no expert, I am just giving the answers I have received before when asking. I know there are temp. bypasses on a lot of the external ones and I am not saying it makes sense, that is just what I have been told.
07-30-2010, 12:21 PM
Yes the 5 speed radiator is sans internal cooler and would make sense to be same size.
07-30-2010, 04:17 PM
use distilled water
local or tap water should not be used. Distilled water is common practice to be mixed with the Toyota red.
07-30-2010, 04:52 PM
Hey guys, didn't mean to leave you hanging, for some reason my login to this forum only works like 2% of the time.
Alp-- I'm getting a coolant temperature of about 198-204 (in 90s outside). This is within normal limits according to Toyota, but I was running in the 180s before I changed radiator, etc
Domstriker-- The guy I talked to said that the tranny fluid needs the controlled environment (temperature wise) that only the radiator can really provide with the large amount of heat transfer fluid that's in it. If you need it cooler, then add the Aux cooler. He says that the fluid mixing (milkshake) happens on all types of vehicles. He definitely thought it was a good idea to put a new radiator in as a preventative measure. I was on the fence about what to do, but I tend to agree with him about bypassing the radiator cooler. He also mentioned that Jeep Libertys have only external cooling (none in radiator) and that many of these trannys have crapped out after 70k.
06 4x4 Taco
