I know a lot of people run OME springs, but I see many of them pairing it with other brands of shocks. Just wondering if the full OME kit is good too, or if there's a reason people just buy the springs.
I'm in the early stages of planning my suspension upgrade. Mine is original, sagging, and rides like I have no suspension at all. Ok, maybe not quite that bad, but it is harsh.
I want a little bit of lift, but not too much. I would consider 3 inches too much.
I was looking at this kit.
https://bilsteinlifts.com/shop/toyot...oyota-4runner/
I'm thinking 880's on the front and 906's on the rear. And I assume the soft valve shocks would be best for on road performance. I may off road some, but nothing too extreme.
Would that have me sitting a little bit higher than a stock '99 height? I have a 2002 Sport. And I assume with that combo I don't need to worry about dropping the diff or anything.
Final question, with that setup what size wheel/tire could I go up to without any rubbing issues? I'm thinking of keeping the stock wheels/tires for summer driving, and eventually getting a second set for winter that are a bit larger and/or wider. Put some knobby snow tires on them and only run them in the cold months, or if I'm doing some off road stuff.
