Old 05-05-2017, 02:57 PM #46
SaulG's Avatar
SaulG SaulG is offline
SaulG is on a distinguished road
SaulG's Avatar
Red/Pink/Yellow/Blue/Green all are offered in low silicate HOAT...
Red and yellow = pink/orange ( pink+pink+red =ok)
Green and yellow = chartreuse ( green+green+yellow=ok)
Orange and yellow= gold or ? ( orange+yellow=who cares)
Blue and yellow=green ( blue +yellow+yellow= change it)
Red and Blue=violet (blue+red+pink=desperate)
Red and Green=BROWN (no one wants their radiator full of shyt)
SaulG is offline   Reply With QuoteReply With Quote
Old 05-05-2017, 07:56 PM #47
RedSled's Avatar
RedSled RedSled is offline
RedSled will become famous soon enough
MY GARAGE
RedSled's Avatar
MY GARAGE
You made me LOL.
2017 Silver SR5 Premium 4wd
02 SR5 Sport 2wd. - Sold
Greed and corruption are rampant.
RedSled is offline   Reply With QuoteReply With Quote
Old 01-09-2020, 10:28 AM #48
Agriess's Avatar
Agriess Agriess is offline
Real Name: Andrew
Agriess is on a distinguished road
MY GARAGE
Agriess's Avatar
Real Name: Andrew
MY GARAGE
Didn't realize this was a 3rd gen thred as I have a 4th gen, but nevertheless, this is usually what I go with, I don't do a good job of checking the engine coolant, but never had a problem yet. I just fill it to the recommended level when I catch that it's low. I just bought it today cause I'm tired of my car blowing cold air when idle... That and for my little 16 month old so she doesn't freeze. Their might be a little leak somewhere but I just put 1.5k into new tires, windshield, serpintine belt and the SAR or SAS can't remember, airbag warning light that came on.
'05 T4R V6 Limited
Milage: 176k
Agriess is offline   Reply With QuoteReply With Quote
Old 01-09-2020, 12:35 PM #49
brillo_76's Avatar
Real Name: Jon
brillo_76 is a jewel in the rough brillo_76 is a jewel in the rough brillo_76 is a jewel in the rough brillo_76 is a jewel in the rough
MY GARAGE
brillo_76's Avatar
Real Name: Jon
MY GARAGE
It happens. :] That should work. I use Toyota OEM long lasting antifreeze in my older toyotas. I buy the concentrate and mix 50/50 with distilled water. The pink fluid is used in the newer Toyotas as my 09 Camry and my moms 2011 Camry use it.
If I exchange the antifreeze. I go with the long lasting red fluid. I just top off the newer vehicles I use pink.
I dont know alot about the new pink fluid as it probably replaces the older fluid.
1997 4X4 V6 5 Speed Sr5 4 Runner (97 5 speed )
1997 4X4 V6 Red limited 4 Runner (97 Limited)
1998 4X4 V6 Sr5 Red 4 Runner (98 Tetanus1 )
1998 4X4 V6 Sr5 Silver 4 Runner (98 Tetanus2)
2001 4X4 V6 Sport Green 4 Runner (01 Green Sport)
Old 01-13-2020, 02:02 PM #50
kyle_seal kyle_seal is offline
kyle_seal is on a distinguished road
I disagree with those saying that factory didnt put in red coolant until 99, my 98 had red coolant in it from first timing belt job.
kyle_seal is offline   Reply With QuoteReply With Quote
Old 01-13-2020, 02:12 PM #51
TRAILBUS TRAILBUS is offline
TRAILBUS is on a distinguished road
Changing the coolant on a regular basis is just as, if not more important than the brand you use. Find one that meets the requirements and stick with it.
TRAILBUS is offline   Reply With QuoteReply With Quote
Old 01-14-2020, 03:02 AM #52
pluton's Avatar
pluton pluton is offline
Real Name: Keith
pluton will become famous soon enough
pluton's Avatar
Real Name: Keith
Originally Posted by mtbtim View Post
I already carry enough shit when I take road trips. Do I now want to add a jug of Toyota Red concentrate and a jug of distilled water to my list of things to carry around? Not really. It's pretty rare to have a hose burst on you especially if you've done preventative maintenance and replaced old hoses, but I figured I'd chime in with my thoughts on the subject.
Tim, I also do not want to carry coolant on remote trips.
Question: If a hose blew and one had to add coolant to the system after the repair, couldn't one just put clean water into the cooling system for a few days or a week without doing harm?
pluton is offline   Reply With QuoteReply With Quote
Old 01-14-2020, 12:33 PM #53
Bad Luck Bad Luck is offline
Real Name: Patrick
Bad Luck has a spectacular aura about Bad Luck has a spectacular aura about Bad Luck has a spectacular aura about
Real Name: Patrick
Adding any water to the coolant will change your ratio and therefore your freezing/boiling points, but it will be fine in the short term. The preferred water to add is distilled water because it doesn't have as many minerals to corrode as tap or bottled water. I would flush my coolant sooner than later after adding tap water to my cooling system.
2000 Limited V6 Auto E-Locker
Old 01-14-2020, 02:32 PM #54
3bears 3bears is offline
Real Name: Joshua 3 Bears
3bears will become famous soon enough 3bears will become famous soon enough
I always carry a jug of water/antifreeze on remote trips. One time I had a hose blow on a remote back road and had to make several long walks to a stream with a water bottle, at night, to refill the system so I could get out.
replaced lower rad hose and flushed system on my return to civilization.
Used duct tape and the clamp off my intake hose over the hole area...leaked...but I got out. I also now carry rescue tape.overheated the car, that's how I knew I blew a hose..no issues with head gaskets etc, so I was lucky. At first I though I did, but that poor running was related to the clamp off hose on the intake up by throttle body, so fuel air ratio was not correct.
I now use the full strength red antifreeze and mix to proportions needed to get to minus 50.
when I lived in Oregon, would mix 50/50 with distilled water.
2000 SR-5 V6 Auto . Desert Dune, Spectre intake, Borla muffler, Magnafine tranny filter, B&M cooler, Talls, KYB, Airlift 1000, DRL delete, Big 3 wire, full rack, TBU, Swapped in Elocker, some LEDs, PIAA headlights, , Amsoil
Old 01-14-2020, 03:05 PM #55
phattyduck is a name known to all phattyduck is a name known to all phattyduck is a name known to all phattyduck is a name known to all phattyduck is a name known to all phattyduck is a name known to all
Down here in SoCal, I mix 40/60 antifreeze/water for higher heat capacity (better engine cooling). That's a good reason to stick with the non-diluted Red...
'16 Honda Odyssey
Old 01-14-2020, 04:40 PM #56
Dieselchessy Dieselchessy is offline
Dieselchessy will become famous soon enough
I use Green stuff. The latest with added corrosion inhibitors, long life 5 year/100K stuff. I've never owned a Toyota that had the red stuff.
Sometimes I add "water wetter". Mostly cause I like the name and the theory. My rigs still run 189 to 192 degrees despite the claims of 20-30 degrees cooler. I dream that it somehow reduces hot spots in the heads.
If I've ever had issues from silicates I didn't realize it. The green stuff hasn't caused me any issues.
Owned 82, 83, 87 pickup, 98, 99 SR5 4runner
Currently own a 98 SR5, 5spd, 4x4, e-locker, no sunroof.
Dieselchessy is offline   Reply With QuoteReply With Quote
Copyright © 2019
