Old 08-13-2010, 05:44 PM #1
trickyrabbit trickyrabbit is offline
trickyrabbit is on a distinguished road
What ELSE to do when doing suspension?
Greetings all, I am new here. I have owned a Stock 1998 Toyota 4Runner SR5 for about 4.5 years. It has dealer installed brush guard, bug deflectors, and running boards. Thought about selling it to get something that will hold more children (Honda Pilot) but that was just too expensive so I decided to just make it a nice again.
The Plan:
17" FJ Cruiser Rims (bought a set for $200 w/o center caps)
Running board removal
OME suspension (ordered today)
Tundra big brake upgrade (plan on ordering tomorrow)
Deck plate mod (bought at boat store last week)
I Needs suspension so I decided to upgrade to OME. It has about 137k miles and I live in the mountains with snow and salt and took it airborne on the beach once. I plan on doing the OME upgrade myself and removing any rust I find under the truck in the process and prime/rubber coating it. What else should I check/do while I have the suspension apart? Sorry for the long post and thanks in advance for any replies.
trickyrabbit is offline   Reply With QuoteReply With Quote
Old 08-13-2010, 09:10 PM #2
steezemcqueen's Avatar
steezemcqueen steezemcqueen is offline
Moderator
Real Name: Dylan
steezemcqueen will become famous soon enough steezemcqueen will become famous soon enough
Moderator
Real Name: Dylan
steering rack bushings and sway bar bushings would probably be a good idea
The Rock Turtle Lifted, Locked, Boosted, Armored, TacoBoxed, and awaiting destruction.
steezemcqueen is offline   Reply With QuoteReply With Quote
Old 08-15-2010, 10:02 PM #3
Thanks. I was planning on doing the stabilizer bar bushings but didn't think about the steering bushings.
Old 08-16-2010, 01:12 AM #4
Spish Spish is offline
Spish is on a distinguished road
SS adjustable trac/panhard bar
If you don't stand behind our troops... feel free to stand in front of them!
97 Limited
- 17" Tundras/285 Duratracs, Spidertrax, Toytec Ultimate lift/ Toytec 1" body lift/ SS adj Panhard bar, Deckplate, 4X innovations DOM sliders, Some stickers for extra power
Spish is offline   Reply With QuoteReply With Quote
Old 08-17-2010, 12:21 AM #5
I that necessary? I was under the impression OME tried to design the lift so you didn't need to do stuff like that? But hey, I am new at this. Thanks.
Old 08-17-2010, 10:02 PM #6
From what I've read it is, here is some info from Steve at Sanoran Steel. He was using the drop bracket until he came up with the adjustable bar, talked to him and this is the best (and right) way to do it. Just look at how Jeeps do lifts.
1996-2002 Toyota 4Runner 2.5" Trac/Panhard Bar Drop Bracket
97 Limited
Old 08-18-2010, 11:03 AM #7
Mauzer's Avatar
Mauzer Mauzer is offline
Mauzer is on a distinguished road
Mauzer's Avatar
Might as well do the upper and lower ball joints while you've got it apart, and you only need the adjustable panhard if your using LC coils and even then its still debatable.
And we drive yoters not Jeeps, its a whole different beast
2002 SR5 4x4- Resurrection in Process
Originally Posted by t4r4life View Post
i like how my nipples are all smooth and pointy all six of them, sometimes i rub them when they get dirty
Mauzer is offline   Reply With QuoteReply With Quote
Old 08-18-2010, 11:55 AM #8
Should have been more specific, most lift kits for jeeps use a adjustable or extended panhard bar. Steve at Sanoran Steel is the resident Toyota guru, just ask him about it he can steer you in the right direction. I always say do it right the first time, I mean we are talking about your suspension, don't half ass it.
97 Limited
Old 08-18-2010, 12:05 PM #9
Mauzer's Avatar
Mauzer's Avatar
I should have been more specific as well, the tracking on the rear axle is a cosmetic issue not a suspension issue. If you don't re-align the panhard your axle will stick out further on one side, to fix this you can use a drop bracket or the adj. panhard bar. Which is the better fix is the debatable part. I know who Steve Schaefer is and I use his products on my rig.
Old 08-18-2010, 02:21 PM #10
Its more than a cosmetic issue, common sense would tell me if my rear is sticking out further on one side there is probably something wrong, pretty sure it would be a problem while driving, and multiplied with greater speeds.
Before adjusted
After bracket (adj bar a better fix)
97 Limited
Old 08-18-2010, 02:31 PM #11
Mauzer's Avatar
Mauzer's Avatar
No common sense tell you that your axle's geometry is shifted, so the rear MAY be a bit squirrely. Plenty of people run their rigs w/ their panhard in the factory position, but that's not what I recommend. I understand that Steve says to do it, but its not a MUST have part.
Old 08-18-2010, 02:34 PM #12
brian2sun's Avatar
brian2sun brian2sun is offline
brian2sun has a spectacular aura about brian2sun has a spectacular aura about
brian2sun's Avatar
It not really a big issue with OME lifts. LC coils lift a lot more and make the panhard more of an issue. There's nothing "wrong", the suspension is designed to "scissor" out and offset to one side. My axle is 3/16" offset to the pass. side with OME 891s. Not noticeable by eye unless you stare and compare. It doesn't feel any different driving either. For all that $$, I just haven't justified welding new brackets or getting an adjustable bar. Not that it's not a good thing to do, it's just doesn't matter that much. If I had LC coils and 4"+ of rear lift I would though.
1997 4Runner 4x4 SR5 - Geared, Locked & Armored
**CLICK FOR '97 BUILD THREAD**
2021 Tacoma 4x4 TRD Off Road Double Cab Short Bed (my DD)
2017 4Runner 4x4 Limited (the wife’s)
brian2sun is offline   Reply With QuoteReply With Quote
Old 08-18-2010, 02:41 PM #13
theizzardking's Avatar
theizzardking theizzardking is offline
theizzardking will become famous soon enough
all that $$$ isn't like a $20-30 dollar part and maybe a 5 minute weld job any monkey can do? maybe like $30-50 in welding cost max?
if you spent 2k or more on a lift/shocks tires why not drop the $100 tops to get this put in and have everything lined back up to relative stock spec?
theizzardking is offline   Reply With QuoteReply With Quote
Old 08-18-2010, 02:47 PM #14
Mauzer's Avatar
Mauzer's Avatar
The adj trac bar is $175, the drop bracket is $50 plus a sixer to get your buddy to weld it for you. All Brian was stating is that it is not a life or death situation if you don't realign your panhard. Your rear axle isn't going to fly off and kill a family of four while you roll your rig and kill a puppy. Its just not that big of a deal, and since this debate can go on forever I suggest we stop hijacking the OP's thread and MOVE ON!
Old 08-18-2010, 02:52 PM #15
brian2sun's Avatar
brian2sun's Avatar
If I'm not mistaken, Steve's adjustable bars are well over $200 + shipping. If you don't own a welder and don't have a garage, once you spend the money on the parts, have them shipped, and then pay a welder to do it (most charge a minimum of 30 minutes) you're looking at over $100. I don't know about you but $100 is $100 bucks and my runner will still get over anything and everything that a runner with panhard mods can do and it still drives just fine on the freeway too.
ome , suspension
