octanejunkie
check this thread out...
realistically, the user should remove the bezel from the hatch to repair this issue.
there are 3 bolts & 4 plastic clips holding this thing on.
2 bolts holding it on are on the handle itself that opens the rear door
1 is part of the rear license plate bezel surround/garnish
the rest are plastic clips, which i h8
so i replaced mine with more bolts. i used m6 and m8's that i had laying around from random salvage yard runs.
>>> comparing the clips vs the bolts
>>> bolt in place of clip
>>> used pliers to pinch the clip so you can push to remove the license plate bezel
the worst part of this job is the you have to roll down your rear window slightly to reach certain clips & i remove the bolts hold the rear window mirror motor so i could move it around.
when removing paneling from the rear, you remove a big black metal backing plate that holds the brain to control the rear window " up and down", so i was constantly plugging this back in to be able to move the window up and down as i needed, to reach the areas that held the bezel on.
